cal914 |
Member ![]() ![]() Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None ![]() |
Took my car out today and it ran real bad,when going up hill's there was no power and made a real rattle noise, the exhaust sounded like it was blowing when you accelerate,it ran fine yesterday,any ideas what could be happening
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
We need more information about your engine setup. (IMG:style_emoticons/default/smile.gif)
cal914 |
sorry ,it's a 1.7 on duael carbs |
Mike Bellis |
Then my guess is a clogged jet. (IMG:style_emoticons/default/beerchug.gif)
cal914 |
when i took it out yesterday going up hill i put my foot down and gave it a bit of a thrashing could this be connected,feels like theres no compression ,but thats me just guessing |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,517 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
(IMG:style_emoticons/default/poke.gif) Where did you find a hill? Do a leak down/compression test or inspect the plugs if you suspect a compression issue.
Bob L. |
Senior Member ![]() ![]() ![]() Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region ![]() |
You may want to start with the basics... Valve adjustment and timing/dwell.
Lo-Fi Version | Time is now: 25th June 2024 - 01:20 AM |
