Oil temp sender drain plug 14mmx1.5, Is that the right size anyone using this? |
shane |
Sep 15 2014, 07:43 PM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
I have a 74 1.8 wanted to use the plug instead of taco plate is that a good choice? Thanks
bdstone914 |
Sep 16 2014, 04:33 PM
bdstone914 Group: Members Posts: 4,735 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
shane |
Sep 16 2014, 05:44 PM
Was thinking that to, it looks like the plug is one solid piece with the sender on the outside, not to much differant then a sender hanging out of a taco plate I would think thanks for your thoughts
Dave_Darling |
Sep 16 2014, 06:36 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The proper "taco plate" is recessed up into the sump. The sender screws into the side of the recess, and there is a cover plate that goes under it. The whole sender is above the level of the bottom of the engine, and it is not exposed to the relatively-cold outside air.
--DD |
Lo-Fi Version | Time is now: 27th December 2024 - 10:29 AM |
