Quick Question, Con Rod Nuts |
kkid |
Sep 18 2014, 11:23 AM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
Hey guys!
Have a quick question to ask. Are there varieties of nuts for connecting rods? I see 2 different nuts combined in the engine that I have been working on. One has a lip on the bottom and other one has a spacer. I just went to PP website and their's looks to be a normal nut as far as I can tell from the pic. Assuming they all should work well but wondering why 2 different nuts were used previously. Which one should I pick now? Thanks in advance, kkid (IMG:style_emoticons/default/smile.gif) |
malcolm2 |
Sep 18 2014, 01:49 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Hey guys! Have a quick question to ask. Are there varieties of nuts for connecting rods? I see 2 different nuts combined in the engine that I have been working on. One has a lip on the bottom and other one has a spacer. I just went to PP website and their's looks to be a normal nut as far as I can tell from the pic. Assuming they all should work well but wondering why 2 different nuts were used previously. Which one should I pick now? Thanks in advance, kkid (IMG:style_emoticons/default/smile.gif) My guess someone has been in the engine and did not get new nuts. You should get new nuts for all your connecting rods. |
IronHillRestorations |
Sep 18 2014, 05:07 PM
I. I. R. C. Group: Members Posts: 6,792 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Con rod nuts are one and done.
Use the old ones to check the large end bearing clearances. Install rod bearings with plastigauge in the race and torque to specs using old nuts, once everything checks out OK, use the NEW nuts to assemble engine. |
Lo-Fi Version | Time is now: 27th December 2024 - 09:54 AM |
