Gas smell in the twists |
57lincolnman |
Sep 18 2014, 08:09 PM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
I've been taking my 914 on curvy roads in the North Georgia mountains to check out some recent suspension upgrades. Yesterday, I had the top off and the windows down and noticed a raw gas smell that only happened on the hard corners. Cruising down the highway and there wasn't any smell. Anyone else have this happen? Any thoughts as to what this is? Or maybe it's normal thing when the gas tank is kind of right under your nose.
bzettner |
Sep 18 2014, 08:12 PM
Member Group: Members Posts: 213 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region |
I've been taking my 914 on curvy roads in the North Georgia mountains to check out some recent suspension upgrades. Yesterday, I had the top off and the windows down and noticed a raw gas smell that only happened on the hard corners. Cruising down the highway and there wasn't any smell. Anyone else have this happen? Any thoughts as to what this is? Or maybe it's normal thing when the gas tank is kind of right under your nose. I had that and replaced my gas cap with a new one...problem solved (for me) |
Wdunster |
Sep 18 2014, 08:47 PM
Panel beater Group: Members Posts: 172 Joined: 10-June 14 From: Monroe,nc Member No.: 17,469 Region Association: South East States |
Yep. Gas cap
boxsterfan |
Sep 18 2014, 08:48 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
I had gas vapers in my 74 2.0L. I replaced the rubber seal inside the gas cap, the rubber gasket under the tank filler and the rubber gasket under the fuel sender on the tank.
Got them all from 914rubber.com and it fixed the problem for me. Prior to that I had replaced all the vacuum lines also. You should also check your fuel lines under the tank....make sure you don't have a leak or weeping hose. |
EdwardBlume |
Sep 18 2014, 10:04 PM
When you smell the gas, its the hard seal around the inlet of the tank. I took Dad's car to an ax prior to restoration and you could actually see the gas. Not a bad idea to use new bolts to secure.
toolguy |
Sep 19 2014, 01:53 PM
Senior Member Group: Members Posts: 1,275 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Check the seal between the expansion tank and the tank. . has the little bolts under the gas cap
holding it on. . |
maf914 |
Sep 19 2014, 03:34 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Check the seal between the expansion tank and the tank. . has the little bolts under the gas cap holding it on. . In the past I have had leakage from this rubber gasket. Tightening all of the bolts uniformly solved the problem. Access is to the bolts is pretty tight. Be patient. |
jmalone |
Sep 19 2014, 06:31 PM
Member Group: Members Posts: 119 Joined: 3-July 09 From: reno,NV Member No.: 10,529 Region Association: Northern California |
All of the gaskets mentioned can be purchased from 914 Rubber at bargain basement prices. Replace them all so that you can keep smoking in the car (IMG:style_emoticons/default/biggrin.gif)
TravisNeff |
Sep 19 2014, 08:48 PM
Uh, the overflow line to the neck of the tank??
Lo-Fi Version | Time is now: 27th December 2024 - 04:52 AM |
