> Removing Climate Controls, I want my climate controlled
BeatNavy
post Oct 13 2014, 10:27 AM
Can someone kindly tell me how I remove the climate control assembly from the dash? I've seen pictures of it out but I can't find any references to how it was done. I've got the bezel part way out but it seems to be stuck on something and if I pry any harder on it I'm afraid I will permanently bend it. I can't see under the dash if there's anything hold that and the actual control assembly in place or if it's supposed to "pop" out.
I don't want to disconnect any of the controls. I just want to clean the contacts better and make sure the light is working.
TIA
AvalonFal
post Oct 13 2014, 02:27 PM
There's a bolt at the back holding it to the body sheet metal.
Paul
BeatNavy
post Oct 13 2014, 02:44 PM
QUOTE(AvalonFal @ Oct 13 2014, 04:27 PM) *
Paul
Cool, thanks Paul. Where is it in general? I've looked around and don't see the bugger.
GaroldShaffer
post Oct 13 2014, 03:03 PM
You bought another 914?
To help see better it may be helpful to remove the lower dash pad.
AvalonFal
post Oct 13 2014, 03:19 PM
Gotta get your head really in there!!! Here's a pic:
pilothyer
post Oct 13 2014, 03:25 PM
If the cables are still attached to the air box you can only pull it out so far.
AvalonFal
post Oct 13 2014, 04:03 PM
QUOTE(pilothyer @ Oct 13 2014, 05:25 PM) *
(IMG:style_emoticons/default/agree.gif) but you can pull it out far enough to clean the contacts with the cables still attached.
Paul
BeatNavy
post Oct 13 2014, 04:08 PM
QUOTE(AvalonFal @ Oct 13 2014, 05:19 PM) *
Thanks Paul! I finally see the SOB! I was looking in the wrong spot. I figured it would be on the dash sheet metal, but it's hooked up to the far wall (but you knew that already (IMG:style_emoticons/default/smile.gif) ).
QUOTE(AvalonFal @ Oct 13 2014, 06:03 PM) *
Paul
That's my goal. Just get it out far enough to clean contacts. I did some cleaning while it's still in the dash. I can get the light working, but it's sketchy. I find if I reach in with my finger and push down ever so slightly on the contact I can get it to light with the fan on medium and high. May need to clean that contact some more.
Thanks for everyone's help!
pilothyer
post Oct 13 2014, 04:09 PM
(IMG:style_emoticons/default/agree.gif) That is very true..........You can also clean the contacts without removal by using a pencil eraser on a pencil.
bdstone914
post Oct 13 2014, 04:45 PM
bdstone914
Also look at the plastic between the traces on the board. I have seen several where the plastic gets hot and raises up lifting the finger that contacts the high speed.
- Lo-Fi Version Time is now: 4th January 2025 - 08:44 PM
