d7n7master |
Gary# ![]() ![]() ![]() Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 ![]() |
Hi All,
Need some help (again), What size/length is the window crank screw? thx!! |
d7n7master |
Hokey Smokes!! It's made of GOLD!!
Part #: P905522 Replacement for OE #: N.014.216.1 Price: Was: $3.99 ea. Now: $2.99 ea (IMG:style_emoticons/default/beer3.gif) |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Is it the same as the mirror base screws? If so I have them.
I usually throw in a set when you buy the gasket for $2.99. (IMG:style_emoticons/default/biggrin.gif) |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
PET shows 5 mm x 8mm countersunk head.
You could probably buy a 100 from Mc master carr for $3. |
bdstone914 |
Is it the same as the mirror base screws? If so I have them. I usually throw in a set when you buy the gasket for $2.99. (IMG:style_emoticons/default/biggrin.gif) The head is different and it is 6mm I think. |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
5mm x 8mm flat head machine screw. DO NOT use anything longer! Do that and you'll find out why when you try to open the door from the inside ...
The Cap'n |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
It's a standard late VW (old) beetle handle screw.
Mikey914 |
I'll bring some in, so if anyone need on I can throw in for .25. Should have some money on shipping.
Mikey914 |
Got them in and listed - .40 set of 2 stainless at correct length.
http://www.shop.914rubber.com/914-Window-r...s-0142161SS.htm |
Lo-Fi Version | Time is now: 26th June 2024 - 12:00 AM |
