IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Ok, this is something I've never done. Since the stock 3 port pumps are NLA, who has done an update to the later style 2 port pump.
This is a customer's car, and we are not relocating the pump to the front. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
It's a simple setup.
Input from the tank, filter first, then pump using the larger line. Return line goes from the fuel rail hooked back to the return line, no pump on that side. You may need a few adapters to make the hoses work at the pump. |
Lo-Fi Version | Time is now: 29th June 2024 - 02:30 AM |
