r_towle |
Do you think one could use the later 2.0 series heads to fill and air tank with compressed air using the air injection ports?
This would be for an adjustable air ride suspension. |
roblav1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region ![]() |
How many maximum psi?
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
on a running engine? (IMG:style_emoticons/default/screwy.gif)
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,680 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Probably more efficient to run a pump on a pulley like the air injection pump. But what would you need the air for? The water squirters (IMG:style_emoticons/default/biggrin.gif)
messix |
I run an old a/c compressor for on board air on my jeep with a switch to turn on the clutch to run the compressor. with the idle up a bit I can air up big tires quick and run air impacts on the trail.
Mikey914 |
Honestly I can fix your problem for about $65 and a trip to Home Depot
http://www.amazon.com/Ryobi-P731-Function-...+air+compressor |
Mikey914 |
Sorry forgot for suspension. If you used a 12v pump you could power off the battery, you would just need a tank to store the compressed gas, which you would need either way. The electric pump would be way more efficient, especially on our little motors. How much horsepower to you want to rob?
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Do you think one could use the later 2.0 series heads to fill and air tank with compressed air using the air injection ports? This would be for an adjustable air ride suspension. I doubt it. If I understand your idea you want to use air (exhaust) pumped out of the engine to a tank for air suspension. Using hot exhaust sound bad idea for a lot of reasons and I doubt you would have much pressure considering it is an open system. The electric compressor sounds better. Those are not meant to run for long periods of time either. |
balljoint |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None ![]() |
Rich,
I liked your idea of using the air injection to run a couple of small turbos. What ever happened to those plans? |
r_towle |
Rich, I liked your idea of using the air injection to run a couple of small turbos. What ever happened to those plans? Still working out the details of the oil return lines for the turbos, but I figured I could put a T inline to get some spare air for the low rider suspension while I was plumbing. |
Cap'n Krusty |
Not much pressure in an exhaust system. Be kinda like blowing up a broken balloon.
The Cap'n |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
I like the AC compressor idea. The magnetic clutch would toggle on and off with a pressure switch. Plus adding a train horn along with the air ride would be cool (IMG:style_emoticons/default/idea.gif)
r_towle |
ummm, those horns give me a new idea....wow, wonder what those are from?
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,113 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
a locomotive? there is a rail car in the background.
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Systems available for the BRZ use the electric compressor technique:
http://www.airliftperformance.com/vehicle/subaru-brz/ |
r_towle |
Systems available for the BRZ use the electric compressor technique: http://www.airliftperformance.com/vehicle/subaru-brz/ I know these exist, I am just a bit worried about overloading the already overloaded electrical system, alternator and voltage regulator. With an engine driven air supply I could remove that risk. |
orangecrate |
Member ![]() ![]() Group: Members Posts: 159 Joined: 16-September 13 From: Apache Junction AZ Member No.: 16,394 Region Association: Southwest Region ![]() |
Yah I like those horns. Warp speed Mr Sulu!!
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
messix |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,348 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
electric pumps and air ride are used in mini-trucks all the time. It's very well established. electrical isn't a problem as the pump doesn't run that often if the tank is a good size.
Lo-Fi Version | Time is now: 25th June 2024 - 04:48 PM |
