hndyhrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest ![]() ![]() |
Does this hardware have to be installed when i bleed the brakes? New back discs and am wanting to bleed them this afternoon. So install hardware, bleed, un install ,check vent clarence and then re install. And then burn them in.
steuspeed |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest ![]() |
The pin and clip are for the e-brake cable. The two small clips retain the long pins that keep the pads in place and the X spring on top of the pads. These must be removed anyway to measure pad vent clearance. So the short answer is no.
hndyhrr |
Lo-Fi Version | Time is now: 26th June 2024 - 08:20 AM |
