Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
closed the deal last night for 2 pairs of 4-piston calipers for $200....designed for 22mm rotors, but I see no reason why they won't be okay with the 911 20mm rotors...now to go break into someones garage and get a pair of the billet 4-lug hubs
now back to the rotors.....PP has the fronts for $48 and the rears are $72 each...I guess one good thing is that one normally goes thru front rotors faster than rear rotors...we shall see.... |
BigD9146gt |
OCD member ![]() ![]() Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand ![]() |
Mike, the 20mm rotor will be fine with a 22mm capable caliper.
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
because while the fronts are relatively shallow, and bolt to the hub, the rears are fairly deep, and incorporate a fairly thick and concentrically machined brake drum for the parking / e-brake.
i think i'd take advantage of the thickness differential to run some of those titanium pad insulators, but that's just me. 911 rear brakes have the "opportunity" to do a bigger share of the work since the back is already a lot heavier to start with ... |
Part Pricer |
Believe everything I post ![]() ![]() ![]() Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 ![]() ![]() |
Mueller |
my 964 front brakes rotors are designed just like the rears with the deep offset hubs....you can hardly tell the difference between the 2 just sitting on the workbench (I've only had new rotors and pads for 1 year...just too lazy to change them (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) ) |
Mueller |
thanks Paul....
speaking of rear rotors.....someone made a big-brake kit using 930 rear rotors on the front.....heavier than using an aluminum hat bolted up to a rotor, but less parts to deal with and simpler..... |
Part Pricer |
I actually found them cheaper at El Auto Parts I just didn't look down the screen far enough. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) $49.68 each with free ground shipping for orders over $50. But, if you want them you better hurry. A quick look direct into WorldPac inventory only shows two in stock. |
ArtechnikA |
i thought we were talking about 914-compatible 911 vented rear disks ... anyway, the point is the same - there's an additional machining step, and it occurs not only in a different plane, but it must be concentric with the hub centerline. |
Mueller |
yes, we are, I just went off a little there (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) I do see why they cost more, I guess I feel better complaining about it, LOL |
Mueller |
ever do that in a flat bottom boat? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 10:46 PM |
