> 914World Classifieds Rules
> F/S : 914-6 engine, Ser. # 6405500
Luke M
post Dec 8 2014, 03:45 PM
For sale is a factory 914-6 engine, model # 901/38 , Ser. # 6405500.
I do not have any history on this engine so it's being sold as is.
The engine turns over pretty smooth w/o any binding.
At some point the engine was taken apart and the piston/cylinders where swapped out. The factory 6's came with 2.0 T pistons and steel cylinders. The cylinders currently on the engine are aluminum. I used a camera with a scope on it to check the pistons and it appears that they could be 2.0 S. How do I know this you may ask, Well I have a set of 2.0 E pistons (see pics for reference only) and they look nothing like the ones in the engine. The pistons in the engine have a higher dome with larger depth valve pockets ( see pics ). I checked the cam #'s and the only one that I could barely see is 901 105 109 which is a Solex cam #. The head intake/exhaust ports are 32 mm. The engine is missing 5 rocker arms/shafts on the right side. I will check to see if I can locate them.
I have a (early 911) black engine cooling shroud and front pulley that comes with the engine. If someone needs more info please ask or pm me.
The buyer is to arrange and pay for the shipping costs. I will put the engine on a pallet and strap it down prior to shipping.
*** Sold ***
Thanks,
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
Luke M
post Jan 30 2015, 09:37 AM
OBO...
pete000
post Jan 30 2015, 12:33 PM
Some day I hope some one posts my orig 914-6 engine up for sale, I have a bad feeling it ended up in a dumpster in Norther CA back in the 80's
Case #6404089
dug
post Jan 30 2015, 09:21 PM
Hi Luke,
Did this engine end up not being correct for your car?
I have an entry that says it matched your chassis 2255. If not, what is the correct number?
GLWS.
cheers,
dug
Luke M
post Jan 31 2015, 08:45 AM
QUOTE(dug @ Jan 30 2015, 08:21 PM) *
Hi Luke,
GLWS.
cheers,
dug
Hi Dug,
I sold 2255 at the end of last year. I had the wrong engine (6405500) listed with the car but I did locate the correct engine. The correct engine to 2255 is 6405487 and was sold with the car.
Luke
Luke M
post Mar 22 2015, 01:55 PM
914Sixer
post Mar 22 2015, 05:38 PM
The pistons appear to be early 911 S with the deep pockets. Could be a screamer engine.
Ben and Ralph
post Mar 23 2015, 12:37 AM
Ben
One day...
gereed75
post Mar 27 2015, 01:17 PM
Luke, Still got the engine??? Might be interested.
Luke M
post Jun 10 2015, 09:00 AM
Luke M
post Jun 12 2015, 05:44 PM
Sold.... (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 24th November 2024 - 03:39 PM
