> Cutting Tool, What is the best tool for cutting laierd sheetmetal/no torch
xperu
post Dec 11 2014, 03:10 PM
TEXAS
I have a small area I want to cut out which is like two ply metal. Is a metal cutter best or jigsaw. I will have to buy whichever one, so I thought I'd ask. Thanks Mike
post Dec 11 2014, 03:22 PM
QUOTE(xperu @ Dec 11 2014, 01:10 PM) *
3" thin carborundum blade. X on the Jig Saw
madmax914
post Dec 11 2014, 03:38 PM
If its in an open area an mostly flat I'd use a jig saw with a metal blade. If its tight and uneven I'd use a 4-1/2" cut off wheel on a grinder. If you're cutting out an area and not starting on the edge you'll need the cut off wheel to cut through the metal so you can use the jig saw.
stugray
post Dec 11 2014, 03:54 PM
If you have the room to get in there, my first choice would be a rotary cutoff tool.
The pneumatic ones from HF work great and they come in different orientationsof the disk wrt the handle.
Only about $10 if you have compressor.
http://www.harborfreight.com/air-tools/spe...tool-69473.html
Mark Henry
post Dec 11 2014, 05:35 PM
that's what I do!
A small angle grinder with a razor blade grinding wheel does a nice job.
barefoot
post Dec 11 2014, 07:21 PM
I've used a multi-tool. HF sells one and has lots of cutting wheels/saws.
It's a fast oscillating tool, so differs from a cut-off wheel pneumatic tool. But you can start in the middle and not at an edge.
Amphicar770
post Dec 11 2014, 08:19 PM
http://www.eastwood.com/air-body-saw.html Easier to maneuver than a jigsaw.
A cutoff wheel makes some clean, straight cuts as well.
- Lo-Fi Version Time is now: 15th January 2025 - 05:43 AM
