> Sloppy shifter, how do you finally fix this?
brooks944
post Dec 21 2014, 03:48 PM
I can move my shifter quite a bit in every direction. Already tried the JB weld fix a couple of times but it still gets loose. I don't have a welder, what is the next best way to fix this?
Thanks,
Rick
post Dec 21 2014, 04:25 PM
Side shifter? Firewall bushings, cup washer & new bushings on side plate, and new conical screws. Shift it by the shift lever on the trans by hand to see if there is any internal slop.
JawjaPorsche
post Dec 21 2014, 04:35 PM
JB Weld? So it is not your bushings but your shifter shaft is busted.
Put a WTB in classifies. Be sure to state for side or rear shifter.
messix
post Dec 21 2014, 04:49 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
do you know any one with a wire feed welder?
you can disassemble the shift lever assembly and file/grind a couple of spots to spot weld the pivot ball on the lever, the dress the weld and reassemble.
I did this and it only toke about 45min to do so.
brooks944
post Dec 21 2014, 05:29 PM
My car is a 75, and I am new to 914's is that a side shifter?
Thanks,
Rick
post Dec 21 2014, 05:34 PM
Yep, that's a side shifter. If you don't want to weld a part pm Gerald Shaffer here. He's on your side of the country. Otherwise, Bdstone here but he is on the West Coast.
wndsnd
post Dec 21 2014, 05:36 PM
You wanted a horse, but got a goat. Nobody wants a goat....
What and where are you welding?
John
messix
post Dec 21 2014, 05:52 PM
if you disassemble the shifter you will see the pivot ball was epoxied to the sift lever, this is where you will file/grind in to the ball and lever a flat spot or two to weld at and then dress the weld to make it blend it to the lever and ball.
rhodyguy
post Dec 21 2014, 06:23 PM
what's your time worth? buy a good used one, replace the 2 bushings that cradle the ball on the lever and put it in the car. 0 down time. the 2 bushings make a big difference with the shifting.
Wdunster
post Dec 23 2014, 10:15 AM
Panel beater
One solution I found is to utilize an old steering shaft. Take the u-joint off to use at the shaft coming out of the firewall. It uses the same diameter shaft. You will need to cut a slot in the shaft for the sinch bolt. On the shift rod itself you will weld the spline portion onto the end after removing the joint. Once I did this my shifter was much more precise.
GaroldShaffer
post Dec 23 2014, 07:29 PM
You bought another 914?
QUOTE(76-914 @ Dec 21 2014, 05:34 PM) *
(IMG:style_emoticons/default/bye1.gif) I sent you a PM.
Dr Evil
post Dec 24 2014, 10:05 AM
Send me your transmission!
I got them, too, if Garold doesnt. I can spot weld yours, too. In OH (IMG:style_emoticons/default/smile.gif)
brooks944
post Dec 24 2014, 11:20 AM
Thanks, replied to Garold's PM and likely to buy one of his intact shifters. As always, appreciate the advice from everyone.
Rick
colingreene
post Dec 24 2014, 03:44 PM
Talk to Glen at Pelican parts and order all the new bushings also
I just did it, helped me quite a bit.
EdwardBlume
post Dec 24 2014, 03:53 PM
I just installed a new firewall bushing on Dads car and it made a world of difference!
jimkelly
post Sep 25 2015, 07:39 AM
Delaware USA
how many are running this upgrade? comments? pics?
thanks
jim
- Lo-Fi Version Time is now: 5th January 2025 - 01:07 AM
