WTB - door switch, need a door switch for a 71 914 |
potomacmidget |
Dec 28 2014, 09:15 PM
I gotta have more cowbell.... Group: Members Posts: 161 Joined: 27-March 11 From: Maryland Member No.: 12,860 Region Association: North East States |
Hi All,
Looking for a door switch for my 71, 914. Looking for the switch that works the interior light. thanks in advance, Reg Kidd |
bdstone914 |
Dec 28 2014, 10:22 PM
bdstone914 Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
JeffBowlsby |
Dec 28 2014, 10:29 PM
914 Wiring Harnesses Group: Members Posts: 8,560 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
4 pole was used through 1973.
potomacmidget |
Dec 29 2014, 10:22 AM
Hi All, Looking for a door switch for my 71, 914. Looking for the switch that works the interior light. thanks in advance, Reg Kidd I will defer to Jeff's knowledge, I guess I need the 4 pole -as I have a 1971 car. The current switch won't work the light, and I found that a prior owner had cut away some wire insulation to indeed verify that the switch was getting power (I did the same thing and then accidentially shorted the wire and luckily only blew the fuse. I am guessing the switch is bad and am willing to give another switch a try. Any advice on removing the switch? It seems particularly tight in there. thanks, Reg |
bakerj |
Dec 29 2014, 10:35 AM
Newbie Group: Members Posts: 22 Joined: 28-August 14 From: central IL Member No.: 17,833 Region Association: Upper MidWest |
[quote name='potomacmidget' post='2127561' date='Dec 29 2014, 10:22 AM']
[quote name='potomacmidget' post='2127434' date='Dec 28 2014, 10:15 PM'] Hi All, Looking for a door switch for my 71, 914. Looking for the switch that works the interior light. thanks in advance, Reg Kidd [/quote] I will defer to Jeff's knowledge, I guess I need the 4 pole -as I have a 1971 car. The current switch won't work the light, and I found that a prior owner had cut away some wire insulation to indeed verify that the switch was getting power (I did the same thing and then accidentially shorted the wire and luckily only blew the fuse. I am guessing the switch is bad and am willing to give another switch a try. Any advice on removing the switch? It seems particularly tight in there. thanks, http://www.ebay.com/itm/PORSCHE-914-DOOR-C...=item4ae1dd8b88 |
bakerj |
Dec 29 2014, 10:40 AM
I have bought from this seller with no issues, if you search his other items there is one with 3 pins i believe also available...
Lo-Fi Version | Time is now: 21st June 2024 - 12:05 AM |
