Can't Open Case? |
Can't Open Case? |
VWTortuga336 |
Jan 11 2015, 11:34 AM
Member Group: Members Posts: 285 Joined: 5-October 14 From: Kansas City, Missouri Member No.: 17,979 Region Association: None |
I'm working on splitting the case on my GC code engine. I've taken out all the case nuts and bolts (and double checked, triple checked, then checked two more times for good measure) but I can't open the case fully (IMG:style_emoticons/default/WTF.gif)
3 of the 4 "corners" of the case open very freely, but the one pictured will only rock back and forth, it will not open all the way to separate the case halves. I know this may be a difficult one to answer via a forum post, but anyone have any suggestions as to what I may be missing? Any and all suggestions would be greatly appreciated, I am at my wits end on this one!! Attached thumbnail(s) |
r_towle |
Jan 11 2015, 11:36 AM
Custom Member Group: Members Posts: 24,656 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Is that a picture of the case?
If it is, you may just need a bit more force. Don't use pry bars, use wooden wedges cut to fit. |
VWTortuga336 |
Jan 11 2015, 11:49 AM
Yes, this is my case. I'll give that a shot.
Can you think of any other reason why this would happen? |
SirAndy |
Jan 11 2015, 12:51 PM
Resident German Group: Admin Posts: 41,937 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Can you think of any other reason why this would happen? Bend stud? (IMG:style_emoticons/default/idea.gif) |
VWTortuga336 |
Jan 11 2015, 01:07 PM
Can you think of any other reason why this would happen? Bend stud? (IMG:style_emoticons/default/idea.gif) Kinda what I was thinking too, just didn't want to force it in case I missed something. |
walterolin |
Jan 11 2015, 01:25 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Do you have the six thru bolts out? They have a vibration damper, a small plastic piece, which encircles the bolt, and will lodge in the case.
VWTortuga336 |
Jan 11 2015, 01:34 PM
stugray |
Jan 11 2015, 01:46 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Tap all of the case thru bolts out before trying to separate
r_towle |
Jan 11 2015, 02:07 PM
If you made it that far with all the through bolts removed, it's most likely a bent stud.
Use wood wedges and boards, no metal. |
EdwardBlume |
Jan 12 2015, 08:27 AM
I had the same issue, remove the bolts but take the tabs out, look at where you can apply pressure safely and get it done.
VWTortuga336 |
Jan 12 2015, 08:52 AM
I had the same issue, remove the bolts but take the tabs out, look at where you can apply pressure safely and get it done. Thanks for the info. How did you remove the 3 lower (closest to the sump) through bolts? I can't see how I'll be able to access the plastic insulators. |
stugray |
Jan 12 2015, 09:57 AM
You can drive the bolts all the way out before trying to separate the case.
you will need new plastic insulators if you do that |
r_towle |
Jan 12 2015, 12:23 PM
take a smaller bolt and drive out the through bolts.
The plastic retainers are part of the standard gasket kit, they are junk anyways. rich |
VWTortuga336 |
Jan 13 2015, 09:40 PM
I finally got the case split tonight. I had to remove the stud I suspected was bent and the case opened up with no further issues (IMG:style_emoticons/default/piratenanner.gif)
But, the stud wasn't bent, it had something on it that prevented it from going through the hole in the case half. Anyone have any guesses at to what it could be. It's sort of copper in color and is stuck to the stud big time. It goes about 75% around the stud (IMG:style_emoticons/default/WTF.gif) Attached thumbnail(s) |
r_towle |
Jan 13 2015, 09:44 PM
RTV copper form a gasket maybe.
veekry9 |
Jan 14 2015, 12:15 AM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
copper wire,14-12 ga.
VWTortuga336 |
Jan 17 2015, 10:46 AM
I'm still wondering WHY this would be on the stud. Any theories? (IMG:style_emoticons/default/confused24.gif)
injunmort |
Jan 17 2015, 10:50 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
i have seen people use strands of copper wire as a homemade heli- coil of sorts when there is minor thread damage. not something I would, though.
Lo-Fi Version | Time is now: 22nd December 2024 - 05:37 AM |
