battery charger as 12 volt power supply, OK to test gauge with? |
machina |
Feb 5 2005, 10:19 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
I need to test my temp gauge out of the car.
Is it OK to use a traditional style battery charger for the 12 volt feed? I checked it with a voltmeter and it looked like about 13.5 volt output. Will it damage the gauge somehow? |
fiid |
Feb 5 2005, 11:12 AM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
Battery chargers can provide pretty lumpy power - and I thinkg the vwoltage can be a little higher than it ought to be.
In short: I won't recommend it, but it will probably work fine. Uh - you should be careful of having a battery charger hooked up to a car with FI while uyou are trying to start or run it - the power drain can cause some wierd power spikes which can (did) kill the FI computer (happened to my megasquirt). For a guage it will most likely be okay. I usually use a PC power supply for testing guages and FI stuff though. |
Lo-Fi Version | Time is now: 26th December 2024 - 04:51 PM |
