Rob-O |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region ![]() ![]() |
I got a new pedal board from Mikey 914, very nice. I took off the hardware from the old pedal board but didn't snap a photo of the pedal stop before I drilled out the rivers and took it off the old board. In looking at it, it definitely has a certain direction that it goes back on. One side of the metal piece that holds the plastic bolt/stop has a higher side than the other. Just wondering if anyone out there has a photo of the board that shows the correct orientation.
Thanks! |
Targa70 |
Member ![]() ![]() Group: Members Posts: 80 Joined: 22-March 13 From: Virginia Member No.: 15,683 Region Association: None ![]() ![]() |
Rob-O |
Yes, thanks Targa. I was kind of looking for a profile pic of that area. If I zoom in on this picture, it looks like the higher raised portion of the pedal stop base is at the top.
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,330 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
Here's some
Attached image(s) ![]() ![]() |
Rob-O |
Perfect Garland, exactly what I was looking for. I just ran out to the garage and riveted the piece on.
Where in SE Michigan are you? |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:11 PM |
