> Washer nozzles won't come out..., How to remove black washer nozzles
jack20
post Feb 2 2015, 04:36 PM
I am in the process stripping my 74 for paint. I can't seem to evenly compress the tabs under the cowl at the washer base to get them out. I've used a number of different pliers.
Any hints would be appreciated.
Thanks,
Jack
jim_hoyland
post Feb 2 2015, 05:52 PM
Get that VIN ?
Be carefully: you may loosen the paint around the hole. Been there. If it's really tight try getting som PB Blaster under it and into the hole. The blaster sometimes take time to do it's magig, so let it sit overnight.
914Sixer
post Feb 2 2015, 05:53 PM
Take a pair of side cutters (diagonal pliers) and cut off the ears or the hole base. New squirters are only about $8.
lsintampa
post Feb 2 2015, 07:40 PM
QUOTE(914Sixer @ Feb 2 2015, 06:53 PM) *
jack20
post Feb 2 2015, 08:05 PM
QUOTE(lsintampa @ Feb 2 2015, 05:40 PM) *
Once again you guys have come through.
Thanks very much!
Jack
- Lo-Fi Version Time is now: 5th January 2025 - 12:02 AM
