4 Pages V  1 2 3 > »
> Subaru Engine Swap, It is now the 1971 Ivory Car
AndyB
post Feb 27 2015, 12:39 PM
The Governor is watching me
So I am finally doing the Subaru drive train conversion. I picked up my donor car from a salvage auction for $200.00. Yes the entire car and yes it does drive and run. With that being said I am still looking to those more knowledgable in the Subaru arena. The car is a 2002 Impreza Outback Sport. It has a 2.5l in it and over 200k on the odometer. My plan is to tear the engine down and rebuild it a little more then stock. I have no intentions of dropping in a turbo, that's for another one. Who are some reliable sources for performance parts other then all the usuall Subaru upgrades that would be done on a Subaru. I am concerned about the cooling aspect of the engine. I would like to know what people are using for radiators. Thanks.
CptTripps
post Feb 27 2015, 01:19 PM
:: Punch and Pie ::
Oh man....there are no shortage of options here. The cooling is essentially the same as any other radiator setup like the SB350 guys are doing. LOADS of options there.
coldwater914.com for all the engine mounting bits. Save yourself the headache of fabricating your own. (Unless you were looking forward to that part.)
AndyB
post Feb 27 2015, 02:45 PM
QUOTE(CptTripps @ Feb 27 2015, 02:19 PM) *
Cpt. I have no intention of massive fabrication. Ian at cold water has my list. My only concern is what others are using as their cooling system. But what I am really looking for is those with experiance on a N/A 2.5 l for guidance. Anyone can throw a bunch of parts together, but making them into something street friendly and not stock are two different things.
post Feb 27 2015, 03:12 PM
914-6 GT in waiting
QUOTE(Scarlet75 @ Feb 27 2015, 03:45 PM) *
I have no fabrication skills. I'm buying the radiator kit from renegade hybrids. I understand it's a bolt in solution with some cutting for air to enter and exit. It's about a grand. Not the cheapest solution but probably the best for my needs - eg33 swap
ThePaintedMan
post Feb 27 2015, 03:21 PM
Not to hijack, but before you order the one from Renegade, ask Chads74 about his Renegade radiator experience. For $1,000 you get a radiator that leaks within 3 months after installation and they refuse to repair it. (IMG:style_emoticons/default/mad.gif)
DBCooper
post Feb 27 2015, 06:19 PM
14's in the 13's with ATTITUDE
Huh. Mine's been in there for eight years now without any problems, though they've probably changed a lot of things in that long a time. I think the only significant advantage of their kit is the shrouding that's been worked out pretty well. It's a thousand bucks, though, and that's quite a lot for shrouding.
AndyB
post Feb 27 2015, 06:58 PM
QUOTE(DBCooper @ Feb 27 2015, 07:19 PM) *
Personally I am a fan of Ruby914's shroud. Now there is a person with skills.
AndyB
post Feb 27 2015, 07:05 PM
QUOTE(ThePaintedMan @ Feb 27 2015, 04:21 PM) *
No worries George. I am not a big fan of them in general. But if they do have something that I need then yes I will order from them but a $1000 radiator is not on my short or long list
Mike Bellis
post Feb 27 2015, 07:08 PM
Resident Electrician
Most likely you could use the radiator from the donor car and build a shroud. Anything is possible. The Scirocco radiator is small and aluminum units are very efficient.
(IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
AndyB
post Feb 27 2015, 07:10 PM
QUOTE(Mike Bellis @ Feb 27 2015, 08:08 PM) *
I knew you would weigh in Mike thanks. And are we talking origional scirocco?
AndyB
post Feb 27 2015, 07:12 PM
DB are you running a turbo?
Mike Bellis
post Feb 27 2015, 07:30 PM
QUOTE(Scarlet75 @ Feb 27 2015, 05:10 PM) *
No. I'm talking about a "Scirocco" radiator like you would find at Summit Racing or Jegs. They are about the smallest unit on the market and would be great for a modest Subi. The key in any radiator is controlling air flow.
JRust
post Feb 27 2015, 07:32 PM
The nice thing with a NA suby is they are easy to cool. I would use the one in the car to start. Bob had one for sale int he classifieds that was perfect. Didn't have the shrouding but you can do they pretty easy. I have a renegade setup in my old v8 car. I had zero problems with it.
DBCooper
post Feb 27 2015, 07:37 PM
QUOTE(Scarlet75 @ Feb 27 2015, 05:12 PM) *
Yes. When I bought that radiator the intention was to put in a SBC, but then changed to Subaru mid-process. It's way more than enough cooling, gotta give it that.
post Feb 27 2015, 09:29 PM
George, if his radiator leaked at 90 days then he needs to check the voltage in his coolant and be sure he has a ground strap on the tranny. That or a terrible mismatch of materials in his system. Opps, back on subject; Plus one on the Sirocco radiator. $60 bucks shipped on Ebay. Add a set of Dodge fans for another $60. Looking forward to another conversion thread. (IMG:style_emoticons/default/beerchug.gif)
AndyB
post Feb 28 2015, 06:54 AM
QUOTE(76-914 @ Feb 27 2015, 10:29 PM) *
Which Dodge fans? Thanks
AndyB
post Feb 28 2015, 06:55 AM
QUOTE(Mike Bellis @ Feb 27 2015, 08:30 PM) *
Mike thanks for the clarification.
post Feb 28 2015, 10:29 AM
QUOTE(Scarlet75 @ Feb 28 2015, 04:54 AM) *
2003 Dodge 300M or Intrepid
Sirocco Radiators 1985-1992
AndyB
post Mar 11 2015, 04:50 PM
So like many things this has now turned into a since I am doing this anyway project. The car will be stripped down to its chassis and be redone. The final color is not determined yet, however it will be in the red family. So these showed up this morning at my door step. The guy left them there as I was getting ready to open the garage door to say something. Funny the tag says inspect before accepting (IMG:style_emoticons/default/dry.gif)
Best part is my wife wanted me to get those flares. And so the saga begins. I have no deadlines for this car so its going to be a while.
post Mar 11 2015, 04:58 PM
914-6 GT in waiting
What car is getting the work done? Pics?
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 27th December 2024 - 08:29 AM
