jgiroux67 |
Guitar Shredder ![]() ![]() ![]() Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 ![]() |
What do you need to do to use 944 or 911 flag mirrors? Just drill new holes?
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Do a serch on this. there is a member that posted mounting dimentions and how to.
Good luck. |
Rough_Rider |
Smurf Zone ![]() ![]() ![]() Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 ![]() |
The 944 mirors would need a different base. From a quick glance at my mates 944 i don't see it as an easy bolt on.
You could try this idea. I made some lexan windows, then drilled mounting holes & popped the carbon jobbies on. You can get the mirrors from SPA, or a bunch of ebay sellers. Attached image(s) ![]() |
Dr Evil |
Nice dog, Trev! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Ofcourse the 944 wont work, they are like 1/3 the price of the 911 and the only difference is the base (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Damnit (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) |
jgiroux67 |
Why would a 944 base not work?
Trev, I was just thinking about those mirrors you have. Could you post a picture of the whole car? I have flared fenders so I'm worried that they might not look good on my car. Also, seeing the price on ebay of those I'm guessing that they are fake carbon fiber, is that true? |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Have you guys ever looked at 935 style mirrors?
The early cones are way cool, up high. (functioning) M |
marks914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None ![]() |
Here is how to adapt Any mirror base to fit any car:
1. Place some blue masking tape on the mounting area. 2. Have a helper or make a jig that holds the mirror in place securely. 3. Rough up the bottom and lower sides of the base of the mirror flag. 4. Mix some bondo or dura glass and apply to the base of the mirror and make a "squash" by placing the mirror in the appropriate spot with your helper or jig. 5. Before the filler fully kicks, pull the mirror off the car and cut any excees with an exacto knife. Finish as nessecary. 6. Sometimes you can reuse the original gasket, sometimes you have to make one. I used 85 escortpower mirrors. $5 each! I hope that helps Mark Attached image(s) ![]() |
Dr Evil |
I was just looking at the escort mirrors. Nice. Thanks for the tips. How about a close up of your mounting?
I have a set of RX7 mirros with switch that I was gonna use, but I think that I am starting to like the flag look better now. |
Dr Evil |
Here is a pic wih the difference shown. 911 = easy to install, cost more Attached image(s) ![]() |
Dr Evil |
944 = need to work some majic, cost less
Dr Evil |
They look similar, but the contours are slightly different at the base.
HTH |
xsboost90 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 ![]() |
so why not take a grinder to the base and make it fit the car?
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
935 mirrors? How about these "cones" They are there, but they SUCK to see anything out of. That's why there is a "WINK" mirror in the car. That thing ROCKS! Attached image(s) ![]() |
redshift |
Shaped like that, but larger, and made not to mount into the corner, but along the front of the 'vent' window, mounts about 2/3 the way up..... eye level.
M |
mack914 |
Member ![]() ![]() Group: Members Posts: 387 Joined: 5-July 04 From: Toledo, Oh Member No.: 2,306 ![]() |
When fitting your 928-944 flag mirrors on your 914; 911 bases, mounting screws, gaskets for bases, and reinforcement plates for doors (fits inside door skin and helps support mirror) are the parts you need for conversion. All the flag mirror portions of the 928-944 mirrors are the same as 911, its just the bases that are different and contoured to fit the 914.
jim912928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) with mack914. I't real important to remember the reinforcement plates (porsche parts...not expensive...like 7-9 bucks) that go inside the doors. It gives strength so you don't bend up the door skins.
Jim Attached image(s) ![]() |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,512 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
I used those Escort mirrors on me BMW 2002 about 15 years ago. They work well. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:27 AM |
