57lincolnman |
Member ![]() ![]() Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California ![]() |
I just got into Jacksonville for the meet-up for the 914 group at Amelia Island. I drove down from Atlanta and started having some issues with cylinder head temp sensor. It started out as a slight skip at highway speeds and has now progressed to full buck coming out 2nd or 3rd gear. I've had this problem before and it was solved with a new cylinder temp sensor.
I need a recommendation for a repair shop here in JAX. I'm staying out at Hampton Inn at the Airport. I've ordered the replacement from Auto Atlanta and should have it in my hands sometime tomorrow (Saturday). I just need someone that can put it on for me. I don't think the car is drivable for the 6 hour ride back to Atlanta. Thanks. |
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
I just got into Jacksonville for the meet-up for the 914 group at Amelia Island. I drove down from Atlanta and started having some issues with cylinder head temp sensor. It started out as a slight skip at highway speeds and has now progressed to full buck coming out 2nd or 3rd gear. I've had this problem before and it was solved with a new cylinder temp sensor. I need a recommendation for a repair shop here in JAX. I'm staying out at Hampton Inn at the Airport. I've ordered the replacement from Auto Atlanta and should have it in my hands sometime tomorrow (Saturday). I just need someone that can put it on for me. I don't think the car is drivable for the 6 hour ride back to Atlanta. Thanks. I'm bringing my tools with me. We can do that in the parking lot, assuming it's the problem. Shoot me a PM and I'll send you my number. -George |
somd914 |
Member ![]() ![]() ![]() Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region ![]() |
Hope AA comes through for you. PM me if something changes with George - might be able to assist depending on the schedule.
Also check your CHT wire and harness - wiggle it around with the car running and see what happens. Had this happen to me - broken harness wire not CHT. |
snakemain |
Ronin Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 14-January 10 From: Aviano, Italy Member No.: 11,232 Region Association: None ![]() ![]() |
And let me know if you need a ride to the thing tonight (or a chase vehicle). I'm in my jeep and staying near the airport as well.
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
We're also at the Airport Hampton Inn in Jacksonville. Let us know if we can be of help. We're in room 217, but flew down so no tools, etc. Brumos Porsche in Jacksonville is a big dealer that may be of help.
We're planning on going to the event tonight, probably leaving the hotel around seven. If needed, you can contact me at eight four seven seven two one two one five six. George |
snakemain |
And if you need tools, I'd bet George (paintedman) would be willing to bring up whatever's required tomorrow when he drives up from Tampa. I only brought a fire extinguisher, battery charger, tire kit, and a leatherman.
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Wow. The thril of all times. Tenner trouble and a dozen tenner mechanics
Within a mile. Hope it's simple but you're in good hands. |
57lincolnman |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
How about substituting a variable resistor (Radio Shack, etc) or fixed resistor if the CHT doesn't arrive from AA?
snakemain |
Looks like we've got him all squared away!
Lo-Fi Version | Time is now: 20th June 2024 - 05:47 AM |
