> Arrived a few weeks ago, At Rodd Point NSW from Oceanside CA
Downunderman
post Mar 29 2015, 11:54 AM
Region Association: Australia and New Zealand
Its been a long process, but its here. The basis for a new historic racer. Its a 72 with a 2l with webers and side shifter. The motor will have to come back to about 1.8. Strangely, I can run either injection or carbs. It seems that when the 914 was originally homologated for historic racing nobody knew much.
I need a few parts, rear boot floor, rockers, front and rear valences, 2l injection - runners, throttle body and plenum, air cleaner, brain. Otherwise its better than expected.
I will start pulling it apart over Easter. The plan is to send it out and get it dipped and see what comes back.
Cheers,
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
TheCabinetmaker
post Mar 29 2015, 12:05 PM
I drive my car everyday
Sheet metal parts can be found at restoration design. I can help with most of the djet parts. Can't help with l jet if you go that way.
damesandhotrods
post Mar 29 2015, 12:32 PM
If you look at pictures of current and back in the day race 914s, the rear valence is left off. As far as the -4 homologation with carbs or fuel injection, I remember reading a story that a deal was struck between SCCA and Porsche allowing them to use carbs, which flowed more air…
Alphaogre
post Mar 29 2015, 10:07 PM
That left my neck of the woods (IMG:style_emoticons/default/sunglasses.gif)
KELTY360
post Mar 29 2015, 11:26 PM
914 Neferati
Nice starting point. What's your issue with the front valance?
Downunderman
post Mar 30 2015, 12:21 AM
I cant run the LE spoiler in the class. It has to be original.
KELTY360
post Mar 30 2015, 08:39 AM
914 Neferati
QUOTE(Downunderman @ Mar 29 2015, 11:21 PM) *
(IMG:style_emoticons/default/thumb3d.gif)
Dave_Darling
post Mar 30 2015, 08:55 AM
914 Idiot
LE air dam was an option for 74+ cars. Not sure if that would allow you to run it, though.
I'd suggest sticking with the carbs for a race car. They should be easier to set up than the D-jet, plus you already have them. Plus, if you're allowed to change the cam, you can get significantly more power with carbs than the D-jet.
--DD
Cuda911
post Mar 30 2015, 09:21 AM
Hello from Oceanside, CA! Looks like quite a project ahead of you. Post pix as you go along with it.
Downunderman
post Mar 30 2015, 12:47 PM
Thanks Curt. I will be in touch down the track a bit. Dave, the Djet box is going to be "fixed" in ways I can't disclose. Trust me, I'm a lawyer.
The motor will have a new crank, rods, barrels, JE pistons, Len Hoffman heads, Webcam 86? that's roughly equivalent to a GE 80 and about 10-11:1 compression. Only just able to drive on the street.
Downunderman
post Mar 30 2015, 12:54 PM
Even though I can get historic registration to drive it on the street in LHD, I'm going to convert it to RHD because its a lot safer to drive, so I have been looking for a RHD dash top. Roger Bray in the UK used to sell them [I think] but doesn't have them on his website. Any clues where I might find one?
BarryM will also need one soon.
GermermanCarGuy
post Mar 30 2015, 01:28 PM
GermanCarGuy
For your Right Hand Drive Dash Pad, I'd start here -- Crawford Industries web page links -
http://www.356-911.com/links/914links.htm
Probably a good place to start would be the Porsche Club GB link.
- Lo-Fi Version Time is now: 4th January 2025 - 07:55 PM
