jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Has anyone installed the Jonsey billet tuna can and had a problem with the sensor ?
Mine does not appear to be cooperating... |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Do you mean the taco plate and the oil temp sensor?
If they chromate or anodize the "billet" (assuming aluminum) then yes you could have a grounding issue. You can check continuity from the temp sensor body to the engine case. Should be less than 10 Ohms (preferably less than 0.1 Ohms). |
jim_hoyland |
Thanks. I'll try that .
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
Has anyone installed the Jonsey billet tuna can and had a problem with the sensor ? Mine does not appear to be cooperating... Jim, I insalled the same sensor on mine as you but did not have an issue. But I have an aftermarket gauge and it runs about 30 degrees higher than the dipstick temperature thermometer. I wonder if you just have a bad wire, ? |
jim_hoyland |
Has anyone installed the Jonsey billet tuna can and had a problem with the sensor ? Mine does not appear to be cooperating... Jim, I insalled the same sensor on mine as you but did not have an issue. But I have an aftermarket gauge and it runs about 30 degrees higher than the dipstick temperature thermometer. I wonder if you just have a bad wire, ? Good possibility. Gonna check it tomorrow when I reach San Simeon. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:38 AM |
