plugging air pump holes, anti- seize or pipe dope |
Triaddave |
Feb 20 2005, 12:22 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
i have a head from a later car that had air pump. i have the hex head bolts (m10 x 50mm x 1.0 mm) to close the holes. should i use some kind of sealant on the threads?
the hex head bolts need to be turned to correct angle so as to clear the manifolds, which is good because they can not back out. what do you think i should do? |
Allan |
Feb 20 2005, 12:33 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I'm going to be doing this as well but havent decided on a sealant. Maybe some high temp pipe sealant used in super heated steam lines. Just make sure that whatever you use will allow you to get them back out or you wont be able to remove the tin.
Bleyseng |
Feb 20 2005, 12:40 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I thought you could use the 10mm valve adjusters in the holes with a high temp sealant.
Geoff |
Aaron Cox |
Feb 20 2005, 12:45 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
can you just cut them off and weld em shut??
Bleyseng |
Feb 20 2005, 12:50 PM
only if the heads are off, then you can have then filled.
You want to drill out and install the breather tubes, Dave or the backpressure will blow out the valve cover gasket and the pushrod tubes. Geoff |
Allan |
Feb 20 2005, 01:14 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) What is this of which you speak? I don't think I ever saw this addressed in other threads regarding this. My motor is all buttoned up. |
Aaron Cox |
Feb 20 2005, 01:17 PM
Allan |
Feb 20 2005, 01:19 PM
Oh that's great. I don't know how to add that. I'm assuming that there is a hose attached to it? Where does the other end go? Is it done on both heads?
Aaron Cox |
Feb 20 2005, 01:22 PM
yes. and yes. drill and tap.... put a hose on. on a carbed car you vent it to the carbs or to a breather box.... the joy s of smog heads (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Allan |
Feb 20 2005, 01:25 PM
So if I don't do this my valve covers will leak and the push-rod tube seals will blow out?
Aaron Cox |
Feb 20 2005, 01:26 PM
and your motor will eat a cam...and your wife will leave you and you will grow old and ugly (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) not a big deal alan you can vent the valve covers if that is easier for you..... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
Allan |
Feb 20 2005, 01:30 PM
What size is the fitting? Can I get directions on the procedure?
Type 4 |
Feb 20 2005, 01:54 PM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
Use Set Screws with hex driver and locktite
Rhodes71/914 |
Feb 20 2005, 02:47 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Allen- to not hijack this thread any more I posted on a thread that I started in December regarding the head breather question.
Allan |
Feb 20 2005, 02:54 PM
Thanks, will look.
Triaddave |
Feb 20 2005, 04:27 PM
thanks for the input to all. you are right about the breather hose on that side, i can still do that and was wondering if it would be an issue. the engine is assembled so welding it shut is not a option. and taking the tin off someday would be a good idea so i'm still thinking like some lock tight,heat may be a problem (with lock tight).
another thought,should i install the insulator gaskets between the heads and the manifolds? is there an issue there as well? i just took off the velocity stacks (again) and installed paper gaskets under them. |
Aaron Cox |
Feb 20 2005, 05:05 PM
i belive its good to use a heat isolating gasket between the heads and the intake manifolds.... keeps the mixture cooler.... |
Triaddave |
Feb 20 2005, 10:18 PM
thanks aaron, the isolater is a good idea,i was just thinking that with the extra tall and wide manifolds that i have that cooling might not be an issue...besides i have the oil cooler mounted in such a way as to get max cooling (in dual grill with fan unit). i'll use the isolators.
Lo-Fi Version | Time is now: 30th December 2024 - 12:25 PM |
