2.0 D-Jet Fuel Pressure, What are you guys running? |
saigon71 |
May 15 2015, 08:29 AM
Advanced Member Group: Members Posts: 2,006 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
The last thing I have to adjust to resolve my occasional bucking issue it the fuel pressure. New TPS board set properly, distributor pulled apart, cleaned & lubed. Engine in a fine state of tune with no vacuum leaks. Timing is spot on.
The car is running like a bat out of hell aside from this occasional buck. The Haynes manual says 28.4 to 29.6. Mine is set at 29. I run whatever gas is available...mostly ethanol "enhanced." What fuel pressure are my fellow d-jetters running? Thanks! |
SLITS |
May 15 2015, 08:41 AM
I always set them at 29 - 30 psig. I have run as high as 34 psig, but backed it down so as not to override the spring in the injector.
worn |
May 15 2015, 08:17 PM
can't remember Group: Members Posts: 3,373 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
The last thing I have to adjust to resolve my occasional bucking issue it the fuel pressure. New TPS board set properly, distributor pulled apart, cleaned & lubed. Engine in a fine state of tune with no vacuum leaks. Timing is spot on. The car is running like a bat out of hell aside from this occasional buck. The Haynes manual says 28.4 to 29.6. Mine is set at 29. I run whatever gas is available...mostly ethanol "enhanced." What fuel pressure are my fellow d-jetters running? Thanks! I wouldn't touch it if that is where you are at. Look elsewhere for the bucking. |
Lo-Fi Version | Time is now: 26th December 2024 - 07:24 PM |
