PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,878 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
Without thinking about my actions, I decided that the shield on my clutch needed to be shortened. It was just too long. What I wasn't thinking about was that the cable itself needs to be shortened a like amount. I called around and got the name of a local business that does this work, but I need to take it by to see what they think.
Two steps forward, one back! Such is life. |
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,446 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Without thinking about my actions, I decided that the shield on my clutch needed to be shortened. It was just too long. What I wasn't thinking about was that the cable itself needs to be shortened a like amount. I called around and got the name of a local business that does this work, but I need to take it by to see what they think. Two steps forward, one back! Such is life. That does sound unfortunate. I have to then ask. Why shorten the outer sleeve? |
PanelBilly |
It was too long.
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
You know it's not really possible for your clutch cable to be too long. Unless, something is bent or broken.
There are times when you may need a small spacer on the adjusting nut but that's about it. |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,354 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Could you possibly have received the wrong cable?
I have heard that happens. |
Lo-Fi Version | Time is now: 11th March 2025 - 12:02 PM |
