> Rare 901 LSD (Expensive !)
pete000
post May 18 2015, 04:03 PM
I knew it was rare to find a 901 LSD gear box. Saw this one on Craig's list... (IMG:style_emoticons/default/idea.gif)
Anyone ever find a 914 with Factory LSD option? (IMG:style_emoticons/default/popcorn[1].gif)
No affiliation with the seller BTW.
914Sixer
post May 18 2015, 07:20 PM
Yes, one was found on a parts car that was up in the rust belt. I believe it went to Glenn Stazak for the race car restoration.
rgalla9146
post May 18 2015, 07:43 PM
I never had a 914 that had a LSD as an option but over the years I'e had two 914 transaxles come my way with OE ZF LSD's One tailshifter and one side shift.
One was in a "rebuilt" trans from a well known 914 parts "dealer" in Easton Pa.
The trans wasn't rebuilt but it had the right type stamped in, and it passed the spin test.
iamchappy
post May 18 2015, 07:59 PM
It all happens so fast!
I have an LSD transmission in my car. I believe it's a factory one. I've never opened it up to see...
ConeDodger
post May 18 2015, 08:06 PM
Apex killer!
QUOTE(iamchappy @ May 18 2015, 04:59 PM) *
I'd hope so Chappy! or you'd still be spinning in place! (IMG:style_emoticons/default/av-943.gif)
euro911
post May 18 2015, 08:13 PM
sixnotfour
post May 19 2015, 08:06 AM
That only fit the early aluminum case 901... The one that fiits the 914 trans uses male stub shafts( a bit longer also) and the bearing journals are bigger.. It can be made to work though ...not worth anywhere near the asking price...
here is the one I converted...
http://www.914world.com/bbs2/index.php?sho...197083&st=0
r_towle
post May 19 2015, 02:53 PM
Custom Member
Well, it might be worth more now that it only works for early 911 cars.
Rich
rgalla9146
post May 19 2015, 04:17 PM
QUOTE(r_towle @ May 19 2015, 04:53 PM) *
Rich
BINGO ! 904...... 906...901 ....!!!
sixnotfour
post May 19 2015, 10:19 PM
I better uncovert mine and throw it on craigslist... (IMG:style_emoticons/default/biggrin.gif)
BTW The one for sale, if you look one bearing has spun on the shaft and has been center punched trying to tighten the bearing fit...... (IMG:style_emoticons/default/dry.gif)
- Lo-Fi Version Time is now: 26th December 2024 - 09:44 PM
