Finally some progress..., or it feels that way. |
xsboost90 |
Feb 22 2005, 09:36 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
Finally after fitting, buying, fitting, dissassembling, cleaning, painting, fitting, assembly and now i have a car w/ calipers-no lines yet or mc- that has four wheels and steers w/ turbo tie rods, 911 brakes and is fully undercoated and welded up. FInallY!!!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/spank.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/givemebeer.gif)
Attached image(s) |
xsboost90 |
Feb 22 2005, 09:37 PM
check out how close the caliper is to the spacer!
Attached image(s) |
xsboost90 |
Feb 22 2005, 09:38 PM
and the bonus, this came in the mail from germany today...will look nice up front when its done! (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
Attached image(s) |
ArtechnikA |
Feb 23 2005, 06:16 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
will you be using longer studs in the hub to get full engagement of the spacer's nuts? you look to be 2-3 turns from full engagement and you'll have leverage working against you. that scares me more than a little ... |
xsboost90 |
Feb 23 2005, 07:14 AM
the studs go all the way to the end, but the way they are grinded off at the ends make them look funky in that picture. The nuts also have a beveled edge that sticks out past the endof the threads, making it look like the studs are farther from the end. I assure you they are completely on there. The wheel bolts are the same way. RIght to the end ofthe stud. They are even torqued to 96lbs already.
Lo-Fi Version | Time is now: 22nd December 2024 - 05:53 AM |
