Looking for Pic's of how the Jack Mounts, for early style wheel well mount |
76-914 |
Jun 22 2015, 06:29 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,646 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'll also need to see the req'd hardware and the location of attach points. You guessed it. I need to relo the jack on my 73 which is a conversion so I thought about using the old wheel style mount. TIA, Kent
Dave_Darling |
Jun 22 2015, 07:30 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The old style only works with the old jack, which is mostly there for decoration...
--DD |
rgalla9146 |
Jun 22 2015, 08:22 PM
Advanced Member Group: Members Posts: 4,671 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
r_towle |
Jun 22 2015, 08:28 PM
Custom Member Group: Members Posts: 24,656 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
It should go in a bag with a real scissor Jack too.
76-914 |
Jun 24 2015, 08:16 PM
The old style only works with the old jack, which is mostly there for decoration... --DD Sorry for the slow response time. Work demands before pleasure. (IMG:style_emoticons/default/biggrin.gif) So it doesn't work so well, huh? I was just looking for a tidy look. I'll also need to see the req'd hardware and the location of attach points. You guessed it. I need to relo the jack on my 73 which is a conversion so I thought about using the old wheel style mount. TIA, Kent ???? I assumed there would be a tab or two to weld into place. It should go in a bag with a real scissor Jack too. And guess what? I have a damn good one from the Subaru that I cannibalized for the conversion. It even has the "cut out" to clear the seam on the bottom of the longs. Guess I'll take the OEM jack out and put the scissor jack in it's place. (IMG:style_emoticons/default/beerchug.gif) |
ChrisFoley |
Jun 25 2015, 08:36 AM
I am Tangerine Racing Group: Members Posts: 7,967 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
There's a pic of the early jack installation on pg 8 of the Haynes manual.
Lo-Fi Version | Time is now: 21st December 2024 - 08:15 PM |
