> 914 Heater, any solutions ?
MecGen
post Feb 25 2005, 05:29 AM
8 Easy Steps
Hi people
Lots of good mods here, on the forum.
Has anybody found, used a heater sytem for the air cooled motor? Oil cooler for example? I am always scarred to plumb oil into the tub...it is a 914. (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
Electric heaters, word is they just don't work.
I don't have stock heat exchangers any more.
Anybody have a decent solution
Thanx 1000 x
Cheers
Joe
(IMG:http://www.914world.com/bbs2/html/emoticons/rock_band.gif)
Trekkor
post Feb 25 2005, 05:58 AM
I do things...
Seems to me that Dan Root makes heaters out of sheet metal that jackets the headers and uses an electric blower to push the heated air.
DIY heat exchangers. Maybe he'll post pics?
KT
MecGen
post Feb 25 2005, 06:21 AM
8 Easy Steps
Excactly what I tryed to do 10 years ago, my exhaust was too rusty and burned holes through it. Would really like to see some pics
Thanx
Cheers
Joe
(IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
BarberDave
post Feb 25 2005, 06:32 AM
Barberdave
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
I have a friend with a 911, that he has a electric heater
that hangs down under the center of the dash. I have never heard him dis it so i guess it works well. ( Jump in anytime Tab. ) Dave (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Bleyseng
post Feb 25 2005, 08:48 AM
Aircooled Baby!
If you are running a header fab something around the tubes and feed it off the fan.
Best heat is 73-74 SSI HE's with all the tin and gaskets, repair all the hoses and stuff and it will cook you out in the morning.
Geoff
sgomes
post Feb 25 2005, 08:57 AM
Electric Member
where is Otmar on this one? I believe he uses two 1800Watt Vidal Sasson hair dryers - Independant driver and passenger controls!! WOOT!
CHAFF
post Feb 25 2005, 09:45 AM
I'm in the process of refurbing and installing a BN2 VW gas heater. Its slow going so I'll post when its done.
-L
Rhodes71/914
post Feb 25 2005, 09:59 AM
Glacier
I took a ride in a members car that had an electric heater hard wired in. It worked fine. Just gotta make sure everything is wired correctly and you have enough juice. Certainly easier than fabing something around the headers.
scotty914
post Feb 25 2005, 10:22 AM
suby torque rules
2 1800 watt hair dryers, no way first they cant be over 1500 watts and use a normal plug, but that does not mean he did not change a plug. 2, that is one noisy way to get heat. 3, thats 3600 watts at 120 volts, or 30 amps at 120 volts, then lets say he had an inverter running from the alt and battery and it was 100 % effecent, that would be 300 amps at 12 volts, or enought to drain the battery flat in 15 minutes even with the alt charging it.
what i used was a coleman heater designed for use in cars, as a emergency heater if you broke down in winter, i mounted it under the dash. between the seats aiming at the back, it was enough to help my leaky HE at 20 to 30 outside temps, here is the one i used in my car. and i never had a problem the 914 is leaky enough to avoid CO stuff
but coleman also makes a 1100 btu heater, as they put it "for rec use in enclosed spaces. that would work by it self to heat a car
Gary
post Feb 25 2005, 02:45 PM
I have one of these Espar D1LC heater in a box. Bought it used for reasonable. Once I get the 914 back from aircooled racing, this is on the short list of installs.
post Feb 25 2005, 02:53 PM
Resident German
QUOTE (scott thacher @ Feb 25 2005, 08:22 AM)
actually, his car has more than just one battery ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) and they're not that loud either ...
as for the heater, a aftermarket heater that burns gasoline is the way to go.
they were an option for VW-Bus and VW-Transporter.
i had one in my VW-Beetle. took about 5 minutes to get the car to sub-tropical temps in the winter with -10C outside ...
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Andy
davep
post Feb 25 2005, 02:54 PM
914 Historian
Not his battery(s).
Hint: his is an electric 914.
post Feb 25 2005, 02:57 PM
Resident German
this is similar to the unit i had ...
http://www.webasto.de/oem/de/am_vans_heaters_833.html
they burn gas from your tank, blow the hot air in your car and the exhaust outside. in my bug i had it mounted under the center of the rear seat ...
(IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy
lapuwali
post Feb 25 2005, 03:14 PM
Not another one!
The OEM unit the Bug guys use is made by Eberspacher, and a search on The Samba's classifieds sections shows several. Some are really cheap ($30), many are quite expensive ($700).
cdmcse
post Feb 25 2005, 03:27 PM
I always wondered what Webasto did. They have some huge manufacturing facility near my house in KY.
IronHillRestorations
post Feb 25 2005, 03:38 PM
I. I. R. C.
Making heat exchangers out of headers made of mild steel is a BAD IDEA! I will go so far as to say it is STUPID!! If you do this then you won't be able to argue this with me at some point in the future because YOU WILL BE DEAD!!!!!
Porsche learned this the hard way when the first 911's came out, and since then (something like 1965) all Porsche exhaust systems have tubing that is a form of stainless, albeit cheap stainless, but stainless none the less. In addition all Porsche heat exchangers have no welds in the exhaust tubing in the heat collectors, which is another killer.
lapuwali
post Feb 25 2005, 03:41 PM
Not another one!
QUOTE (cdmcse @ Feb 25 2005, 01:27 PM)
Lots of car-related parts, mostly sunroofs and HVAC stuff.
don9146
post Feb 25 2005, 03:43 PM
QUOTE (SirAndy @ Feb 25 2005, 03:57 PM)
I have looked into one of these for the 914, but I don't see a good place to mount it...
post Feb 25 2005, 03:52 PM
Resident German
QUOTE (don9146 @ Feb 25 2005, 01:43 PM)
passanger footwell, in place of the hard foam footrest. just build a alu-shield to cover it and have the warm air exit towards the center tunnel.
or, do what Dr. Porsche did, mount it in the front trunk and have the hot air routed into the stock air box, just like the normal heated air ...
that way, you can still use the dash controls to redirect the hot air ...
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy
MecGen
post Feb 25 2005, 05:59 PM
8 Easy Steps
You people rock !!!
I posted this in the morning then left for work. Thanx for all the advise !!!
I have a lot to think about....
I am leaning to a electric heater set-up, I would have to find a heater that my 75 amp altty can handle. Its the easiest solution....but.....I think the gas heater out of an old bug or similar system, might be a better performing system, more dangerous ? Idunno.
It would be cool if someone that had a gas heater in a 914 would post, I can't be the first person to look for a solution....
Thanx again everyone
Cheers
Joe
- Lo-Fi Version Time is now: 4th January 2025 - 06:45 PM
