Speedo stopped working..., right, how do I fix this? |
OllieG |
Jul 12 2015, 03:33 AM
OllieG Group: Members Posts: 212 Joined: 6-July 11 From: UK Member No.: 13,282 Region Association: England |
Hi Folks,
Went for a drive last weekend and put the car away seemingly with everything working. I took it out today but the speedo is completely dead. Electrics aren't my strong point so can anyone tell me how I should go about fixing it? Thanks, Ollie. |
mepstein |
Jul 12 2015, 05:02 AM
914-6 GT in waiting Group: Members Posts: 19,642 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The speedometer runs off a cable. No electronics involved. |
orthobiz |
Jul 12 2015, 07:51 AM
Senior Member Group: Members Posts: 1,757 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
If the cable is properly attached, try tapping hard on the speedo when the car is running. The needle gets stuck some time. Mine did this after an odometer repair and is slowly getting better, like it's healing on its own! It would need a jolt and then it would start working at about 30mph and now at 20mph, hopefully it will continue to improve.
Paul |
Steve |
Jul 12 2015, 07:57 AM
914 Guru Group: Members Posts: 5,764 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
typically there is only 3 things that can go wrong.
-Angle drive on transmission end. Take off cable and try turning the drive by hand. If it turns you need a new one. -Speedmeter cable. Remove speedometer, drive car and watch to see if the cable is spinning while driving. -if the above is fine you need a new speedometer or get it rebuilt |
TheCabinetmaker |
Jul 12 2015, 10:09 AM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Disconnect the cable from the drive gear at the trans.
Use a drill in reverse, with a slotted screw tip to turn the cable. If the speedo turns, it and the cable is fine. If it doesn't, it's either the cable or the head unit. |
Lo-Fi Version | Time is now: 21st December 2024 - 08:09 PM |
