Front Caliper clearance question 3.5" spacing 5 Lug, Wilwood Superlite's |
Vysoc |
Jul 12 2015, 12:28 PM
Vysoc Group: Members Posts: 588 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Hello World,
I am reworking my front 5 lug struts,shocks and calipers. I was able to pick-up a set of Wilwood Superlite 3.5" spacing front calipers with 3 sets of additional brake pads. Upon doing a dry run on fit, I needed to trim my brake dust covers slightly but I noticed that the caliper did not line up in the center of the rotor. Rotors are new Sebro 405 43001 098. Is it possible to use washers to adjust the caliper position to center. I would obviously purchase longer bolts to make sure that the same amount of thread is holding in the strut. The adjustment distance would be approximately 5mm. Thanks, Vysoc (IMG:style_emoticons/default/flag.gif) |
Mueller |
Jul 12 2015, 12:44 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
I've done that before and never had an issue, I'd get hardened washers from MrMetric or McMaster-Carr the thickness and flatness of each washer is more tightly controlled.
914forme |
Jul 12 2015, 12:50 PM
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
Did not know Wilwood made a superlite in 3.5" form |
Vysoc |
Jul 12 2015, 12:56 PM
Yes Wilwood did make a 3.5" spaced Front Caliper it is Light and it is beautiful. Photo's to follow.
Just like my English Shampoo states on the back: "ASKED FOR THEREFORE MADE" Picksniff's. Photo taken will be added on Monday, sorry, I have my photo stuff on my work computer. Thanks, agree needs to be higher quality washers and bolts. Vysoc (IMG:style_emoticons/default/flag.gif) |
Andyrew |
Jul 12 2015, 01:02 PM
I wouldnt hesitate to use quality washers to space a caliper as long as the bolts are high grade..
Vysoc |
Jul 13 2015, 07:31 PM
As promised pictures of the Wilwood Superlite 3.5":
Thanks, Vysoc (IMG:style_emoticons/default/flag.gif) Attached thumbnail(s) |
Maltese Falcon |
Jul 13 2015, 07:43 PM
Advanced Member Group: Members Posts: 4,817 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
...wonder if these are made in 6 piston as well ? (IMG:style_emoticons/default/idea.gif)
Maltese Falcon |
Jul 13 2015, 08:26 PM
...just found the superlite 6 puck @ 3.5" spacing on the Wilwood site (IMG:style_emoticons/default/smile.gif)
Mike Bellis |
Jul 13 2015, 08:42 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Your bleeder screws are on the bottom. Just a mock up right?
Vysoc |
Jul 14 2015, 06:10 AM
Correct this is on the wrong strut, I noticed that when I saw the box had specific Right & Left Calipers and I Colonel Klinked it.
Thanks for noticing!! Vysoc (IMG:style_emoticons/default/flag.gif) |
Elliot Cannon |
Jul 14 2015, 08:59 AM
I used thick washers.
Attached image(s) |
914forme |
Jul 14 2015, 09:21 AM
Oh so nice, Marty P/N for the 6 pucks, and what rotor radius are you thinking. ?
Then that leads to a long slope I was already heading down, next up, pedals, and M/Cs Pondering proper sizing of the MCs? Any body need some heavy 88 Carrera Rotors for there 914, I'll even toss in the GBS Yellows, stops a 914 like a freight train. (IMG:style_emoticons/default/biggrin.gif) They add to the unsprung weight of the car. (IMG:style_emoticons/default/dry.gif) |
Elliot Cannon |
Jul 14 2015, 09:33 AM
Oh so nice, Marty P/N for the 6 pucks, and what rotor radius are you thinking. ? Then that leads to a long slope I was already heading down, next up, pedals, and M/Cs Pondering proper sizing of the MCs? Any body need some heavy 88 Carrera Rotors for there 914, I'll even toss in the GBS Yellows, stops a 914 like a freight train. (IMG:style_emoticons/default/biggrin.gif) They add to the unsprung weight of the car. (IMG:style_emoticons/default/dry.gif) You ever see a freight train try to stop quickly? (IMG:style_emoticons/default/av-943.gif) |
matthepcat |
Jul 14 2015, 09:42 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Looks like the "Billet Narrow Superlite 6 Lug Mount" fits our car.
http://www.wilwood.com/Calipers/CaliperPro...no=120-13383-BK Part numbers: 120-13383-BK (left) 120-13383-BK (right) |
Mike Bellis |
Jul 14 2015, 07:12 PM
Looks like I need some to replace my 930 calipers...
Stupid internet... (IMG:style_emoticons/default/dry.gif) |
914forme |
Jul 14 2015, 08:36 PM
(IMG:style_emoticons/default/lol-2.gif) your right, maybe wrong scenario there. Okay try again, stops like an F-18 that did not miss the carrier deck cable!!! |
matthepcat |
Jul 15 2015, 09:39 AM
Looks like I need some to replace my 930 calipers... Stupid internet... (IMG:style_emoticons/default/dry.gif) 6 pot front and rear? (IMG:style_emoticons/default/smile.gif) Block of wood ebrake |
Mueller |
Jul 15 2015, 10:07 AM
I have to ask...what the heck is that scoring card/chart for?
Vysoc |
Jul 15 2015, 02:03 PM
I took this off the same memory card in my Nikon as one of the Golf Tournaments I ran this season. I am a Golf Professional at a Club in Southwest Florida. After the tournament is over we photograph the Scoreboards, print them out and then file them away with the other pertinent tournament info. So that when Mrs. Hamelfarb wants to know what Mrs. Chetnik shot in the Spring Member/Member we can damn sure accommodate them. (IMG:style_emoticons/default/biggrin.gif)
I have no idea how it got put in the thread as I tried to delete it twice, sorry you had to look at my calligraphy and wonder what the $%^&? Thanks for the good Information! Vysoc (IMG:style_emoticons/default/flag.gif) |
wndsrfr |
Jul 15 2015, 08:02 PM
Senior Member Group: Members Posts: 1,436 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
OK, Here's my Wilwood conversion & I love it.
Initial installation was with Stoptech rotors & I used washers to center the caliper, worked fine. Check out the difference in the pad sizes vs. "A" calipers--massive! However, with those rotors I found that the Wilwoods pads don't sweep the entire disc, leaving about 1/2 inch around the inside next to the hub. They developed radial cracks immediately from the uneven thermal stress leaving me a bit uncomfortable about staying with those stock dimension rotors. So...Installed Wilwood's rotors using the hat sold by Rebel Racing & fabricated a 3/8 inch aluminum bracket to center the pads on the rotor disc radially and axially. Saved a bit more weight and better yet, the replacement rotors are like $30 from Summit Racing--can't beat that. BTW, Here's my Porterfield R4 pads after 3 DE events totalling about 700 miles on track and maybe another 300 miles street driving. The outers have worn more than the inners and when they're pulled there's a noticeable fromt to back taper. Doesn't affect the braking at all--frankly, I'm still overbraking nearly everywhere--just breathing on these monsters takes a lot of momentum out of a 2000 pound car! Be careful about jumping on 6 piston units that you size everything properly front to rear and to suit the ratio with the M/C....My setup is using Wilwood 120-11131 with 1.62 inch pistons to go with "M" calipers on the rear and 23mm M/C. High hard pedal & could probably work better with 19mm M/C....ymmv. |
Lo-Fi Version | Time is now: 19th September 2024 - 03:39 PM |
