MikeM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada ![]() |
Do you guys think there would be any advantage to relocating my oil filter to the firewall? I'm hoping it would reduce my oil temps slightly. My car gets up to 230 sometimes on warm days. I'm thinking about old 911's I've owned, where the oil was run up into the right front fender then turned around and sent back to the tank,cooling the oil. What do you guys think?
Thanks, Mike |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I've done many remote filters, my T4 powered bug has one, it won't make much of a difference.
Add a cooler in the remote filter line then it may be worth the effort. Put the cooler after the filter. |
MikeM |
Thanks Mark...but you see my logic,right? Remember the 2.7 liter 911's?
Mike |
Mark Henry |
Thanks Mark...but you see my logic,right? Remember the 2.7 liter 911's? Mike Yes, but i'd say it's more the steel line running all the way to the front and back that would be having any cooling effect. IIRC Gene Berg tested just the filter and the canister type with fins and only saw a slight (less than 2-5 degree) drop in temps. |
MikeM |
Thanks Mark. I guess the other thing is that it makes the filter easier to change!!
Mike |
mikedsilva |
Member ![]() ![]() Group: Members Posts: 90 Joined: 23-February 15 From: Australia Member No.: 18,462 Region Association: Australia and New Zealand ![]() |
you could always run the lines to the front of the car using steel lines, and have the remote filter mounted up there too !
Lo-Fi Version | Time is now: 20th June 2024 - 05:48 AM |
