FI Intake Runner Gasket Install, cooling tin in the way? |
Bruce Allert |
Mar 4 2005, 12:42 AM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
After re-installing the cooling tin (after painting) I put the phenloic intake gasket on the head to see how the fit was going to be. The tin has 3 tabs that extend under the gasket. Is the gasket supposed to go onto the head first then the tin? When I took the intakes off, the gaskets came with them. I figure the gasket should go over the tin but wouldn't that be cause for a vacuum leak??? Here's the tabs on the tin I'm speaking of.
........b Attached image(s) |
scotty914 |
Mar 4 2005, 12:57 AM
suby torque rules Group: Members Posts: 1,528 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
either trim the tin or the gasket, i personally would shave the gasket not that pretty tin (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif)
Bruce Allert |
Mar 4 2005, 01:01 AM
Thanks Scott on both answers! (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) The tin is under the gasket about an 1/8". As for the tin, I spent two hours cleaning & painting it. Next time I do that it'll be outta the car! (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
......b |
Rhodes71/914 |
Mar 4 2005, 01:02 AM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
I thought the same thing when I was test fitting mine, but under the tabs on the tin there is a space on the head that the tab get pushed into when the gasket is in place.
Bruce Allert |
Mar 4 2005, 01:05 AM
Thanks Sean... that's good news. I learned quite a bit today & yesterday taking this tin off for the first time. There's some cool stuff under there! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
.......b |
Rhodes71/914 |
Mar 4 2005, 01:24 AM
Yeah it kinda sucks you gotta cover it all up.
MattR |
Mar 4 2005, 01:28 AM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
What years is that tin? I didnt notice that when I put my engine together. Maybe I overlooked it?
Bruce Allert |
Mar 4 2005, 09:28 AM
It's a '74. There wasn't too much crap on the cooling fins. Brinkmans brake cleaner took care of that along with the oil cooler. I did have to scrub the bright center area of the engine tho... geeze, what a bunch of built up stuff! Glad I installed the drivers side tin first (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) that was one hard sumbitch to get back in without beat'n the shit outta the new paint. I'll get it finished today & post a pic. ........b |
Dave_Darling |
Mar 4 2005, 01:29 PM
914 Idiot Group: Members Posts: 15,067 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I don't recall the left and right arrowed spots on the engine tin interfering with the gasket on my car. The middle arrow would, if there were not a recess in the cylinder head for the tin to slide into.
--DD |
Bruce Allert |
Mar 4 2005, 03:53 PM
I found the left arrow'd tab did not interfere but the right one sure did. I cliped it and it fits fine.
Not sure how the normal way is to re-install the runners... I installed the plenum then pushed the runners into it. T'was a beotch to say the least. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Had to use a wee bit O' lube!!! (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) .......b |
StratPlayer |
Feb 26 2006, 11:37 PM
StratPlayer Group: Members Posts: 3,300 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
When installing these gaskets do you use any gasket sealer on those, or installed without any sealer?
MattR |
Feb 26 2006, 11:42 PM
No sealer is necessary. |
Rand |
Feb 26 2006, 11:52 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I used silicone spray on the inside of the intake runner seals between the plenum and runners. Popped together nice and easy. Did not use any sealant on the phenolic.
Actually, I used short pieces of radiator hose instead of the official intake runner seals. Get the right size, they fit nice and snug. And cost a fraction of the official part. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Lo-Fi Version | Time is now: 4th January 2025 - 11:17 PM |
