Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
The lines coming out of the firewall, which one is out to the engine and which one is the return?
The one closest to the clutch tube or the one passanger side? Unmolested car, but I'll double check at the tank later to be sure. thanks. |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
On early cars the supply is on the right,
and on late cars the return is on the left. |
Mark Henry |
On early cars the supply is on the right, and on late cars the return is on the left. Ummmmm....what? (IMG:style_emoticons/default/blink.gif) |
theleschyouknow |
Senior Member ![]() ![]() ![]() Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None ![]() |
On early cars the supply is on the right, and on late cars the return is on the left. Ummmmm....what? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/agree.gif) but I thought it was the other way around on early cars the return is on the left on late cars supply is on the right (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) cjl |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Either....
There, now you have three answers. Honestly, they can be switched at the tank, so that will help you decide....how the two rubber hoses are hooked up. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Isn't the supply on the right so it comes up the front hole after turning 90degrees w/o crossing over the return?
OU8AVW |
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region ![]() |
Isn't the supply on the right so it comes up the front hole after turning 90degrees w/o crossing over the return? The front hole is the correct hole. Don't let it slip into the back hole. That is the wrong hole. (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 11:28 PM |
