larryM |
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California ![]() ![]() |
anybody have a template or source for a gravel shield for GT rear flare as pictured in DGBVWP
perhaps a 911/930 e-bay shield will work, but hate to spend $$ just to test one ![]() TIA & see y'all at Rennsport |
AZ914 |
914 Dumbass ![]() ![]() ![]() Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region ![]() |
I was thinking you could mask your own off using pin-striping tape.. shape it any way you like, mask of the rest, then use Plasti-dip and lay on 6-8 coats. I think it would look good, and can be peeled off fairly easily. A can of the stuff is around $5. I did some Plasti-dip on my Audi grill / emblems and was amazed how easy it is to do and how good it looks.
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I'm pretty sure those are 911 ones. Not sure how well they fit unmodified.
(IMG:style_emoticons/default/shades.gif) |
whitetwinturbo |
Honey, does this wing make my ass look fat? ![]() ![]() ![]() Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California ![]() |
...........Porsche installed CLEAR items on the 1997 Turbo which can be cut to shape 914.
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
The picture shows a 930 gravel shield.
Good material but the 930 shape is not a good match for the 914 GT flares. I like the PlastiDip idea. |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Just buy some Black Vinyl and do it that way (3M 1080)
If you dont like it you can peel it off and try a different shape. Or as it wears you can just peel it off and put on a new one. 5ft X 1ft $16 http://www.metrorestyling.com/3M-1080-M22-...atte1080m22.htm or about $5 sqft for clear bra material http://www.metrorestyling.com/Premium-Clea.../paintpro24.htm |
Cracker |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States ![]() ![]() |
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
Use the clear bra stuff if you aren't looking to change color. I've got it on mine & love it.
Maltese Falcon |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,727 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
I bought some black vinyl at Michael's arts +craft supply, made a template and cut gravel shields for this '85 Doka. EZ job
![]() Marty |
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
I used the clear armorguard type stuff on mine did the front ones and lower gt valance also works great easy to install. You can find the stuff on Ebay.
Attached image(s) ![]() |
larryM |
thanks for the ideas
getting a proper "french curve" look was my main concern with DIY - had already made a paper template also had/have concerns about the stuff conforming w/o wrinkles & bubbles cuz even xpel light shields & flat vinyl cling graphics have those issues when installing found this DIY stone guards - Rennlist i will try it with Alpina clear film which i have on shelf . |
Lo-Fi Version | Time is now: 25th June 2024 - 10:00 PM |
