Build no. 2 |
Build no. 2 |
schreiber |
Sep 14 2015, 10:14 AM
Member Group: Members Posts: 137 Joined: 26-June 07 From: Huntsville, AL Member No.: 7,843 Region Association: South East States |
Finally got another 914. Will update as this progresses.
Trailered home Stopped on the way home to get notarized bill of sale; required for tag Checking out chipping paint Removed 4 Autolite plugs; found a 5th stray in the engine tin - all the way from Germany Removed valances, bumpers, rockers, and rear lid. Got help cleaning up |
bandjoey |
Sep 14 2015, 10:20 AM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
God bless you! (IMG:style_emoticons/default/w00t.gif)
schreiber |
Feb 7 2017, 01:11 PM
Slowly removing years of gunk |
mepstein |
Feb 7 2017, 01:18 PM
914-6 GT in waiting Group: Members Posts: 19,679 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Looks like there were at least 4 other 914's in the yard. Someone needs to save them.
JoeDees |
Feb 7 2017, 02:09 PM
Senior Member Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
Was that one in Oklahoma? I think I looked at it a couple years ago.
schreiber |
Mar 1 2017, 09:50 PM
schreiber |
Mar 1 2017, 09:53 PM
Lots of recent photos. Some I'm posting here just so I don't lose them later on.
schreiber |
Mar 1 2017, 09:56 PM
schreiber |
Mar 1 2017, 09:58 PM
schreiber |
Mar 1 2017, 10:03 PM
schreiber |
Mar 1 2017, 10:05 PM
schreiber |
Mar 1 2017, 10:06 PM
schreiber |
Mar 1 2017, 10:09 PM
My first time getting this far into an engine. Trying to figure out what needs replacing. Any initial thoughts on the condition of these lifters? Still useable if I rebuild the 1.7?
Dave_Darling |
Mar 1 2017, 11:54 PM
914 Idiot Group: Members Posts: 15,067 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Hold them nose-to-nose. There should be a slight crown to them, so they should only touch in the middle. If they're flat against each other, they're wiped.
At a guess, they look pretty wiped... --DD |
schreiber |
Mar 7 2017, 10:50 PM
schreiber |
Mar 7 2017, 10:51 PM
schreiber |
schreiber |
Mar 7 2017, 10:52 PM
porschetub |
Mar 8 2017, 01:21 PM
Advanced Member Group: Members Posts: 4,761 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Those barrels look like 96mm "slip in" type ,really thin @ the top (IMG:style_emoticons/default/dry.gif) .
Plan on getting your heads bored out if you stay with 96mm piston kit ,its a good upgrade from stock anyway. |
cwpeden |
Mar 9 2017, 08:42 AM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Hold them nose-to-nose. There should be a slight crown to them, so they should only touch in the middle. If they're flat against each other, they're wiped. At a guess, they look pretty wiped... --DD How much crown? I was out in the shop moving stuff around and decided to look at some I had. Out of the 3 sets not a single one had any crown. |
Lo-Fi Version | Time is now: 4th January 2025 - 09:23 PM |
