mrfourteen |
Member ![]() ![]() Group: Members Posts: 74 Joined: 1-November 13 From: Oregon out in the Mozarks Member No.: 16,596 Region Association: Pacific Northwest ![]() |
Update, I'll be offering this one up for sale when completed.
Here is a link to an album on fickr much better to see progress pics https://www.flickr.com/photos/124793434@N03...157654074622313 I started with a 914 that sat 15 years in dry storage in the hands of a hopeful V8 conversion fan. A stalled project that never happened. So my starting point was an unmolested car with no rust issues. Original books/manuals, keys, radio and so on. This will be a mildly modified back date look with body color bumpers and early steel wheels with hub caps.simple look of the German delivery first series cars. Starting in on the home stretch, glass in and ready for door install Interior is in and wiring connected. Starting to test systems and wake the long sleeping beauty. So far all go except for one headlight wont wake up.I'll be digging in on that as I work thru the rest of electrical check out. Should hang the doors in the next few days. Fuel up and brake check out as well. ![]() ![]() Original carpet is in pretty respectable condition. Steering wheel will get a going over. ![]() Bumpin' sound system ![]() ![]() |
mrfourteen |
mrfourteen |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Dang, great work on stripping that paint...what did you use?
mrfourteen |
Dang, great work on stripping that paint...what did you use? Paint remover, the kind that burns like mad when to get it on you. I don't like to blast as it gets grit everywhere and not as easy to control if you have other parts finished. I use heat on the OEM seam sealer in the form of a propane tourch. Stinky and not fun. |
falcor75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia ![]() ![]() |
Looks like a great start!
mrfourteen |
[quote name='mrfourteen' post='2250833' date='Oct 11 2015, 09:41 PM']
Floors with original factory finish. These were striped and epoxy painted before Roadblocker sound absorption mats were applied. Roadblocker is self sticking butyl rubber with 4 mil aluminum backing, odorless non asphalt, good stuff. ![]() ![]() |
mrfourteen |
Some dash progress
mrfourteen |
trojanhorsepower |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None ![]() |
Looking good. Could you talk a little more about the paint stripping? What brand, what was the process like, did you neutralize.... I want to know all about it!
mrfourteen |
mrfourteen |
Paint scheme concept
mrfourteen |
mrfourteen |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,054 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Wow the removal of the seam sealer makes such a huge difference. Looks great so far!
mrfourteen |
mrfourteen |
mrfourteen |
After looking over the other builds here I can see how boring this build is. No dramatic surgery or radical mods. Good thing I not worried about winning any prizes.I think I should pair it up with my engine swap car to spice it up a little.
Engine ready to go in after bench testing break in run up and basic tuning. 1.9 with fly cut heads, mild cam Dellorto 36s with 29mm chokes single vac. dual advance dizzy with Pertronics, full stainless exchangers and a header on the back. ![]() ![]() in there ![]() top view ![]() I've had and built so many of these it's like sleep walking I'm a 914 zombie just in time for Halloween |
mrfourteen |
mrfourteen |
Lo-Fi Version | Time is now: 2nd April 2025 - 02:26 AM |
