Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
There will be a lack of progress on my car until I get this members 914 running with my v8 setup. The only requirement is that the engine will start, run, and move the car.
![]() Below is my list of work to do. Pull Fuel Tank Replace stock fuel lines Plumb fuel pump Replace firewall shift bushing Cut holes for radiator lines in front trunk Mount radiator lines Cut notch for HEI Dizzy Clearance valve cover Bolt up engine/trans Bolt up cv joints Install shoft linkage and adjust Install distributor and carb Install clutch, throttle and speedo cables Wire starter, dizzy, alternator Test fire Flush coolant Bleed brakes Drive Total hours involved is anticipated at 26 by myself. I origially agreed that the owner would have the car 100% ready for the swap and I would only have to do the v8 portion, (which I have a anticipated at 20.5hrs) however the fuel line issue, firewall shift bushing, and bleeding the brakes are all going to be done on a T&M basis. Overall its a good looking body with a few dents and paint that shows its age. There is a bit of rust in the firewall and battery tray and some in the pass front door jamb, but the rear suspension console looks great. I think its a great candidate for a conversion. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,236 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
That yellow will be a sleeper for sure.
Andyrew |
Progress from last night.
Ready for installing the new prebent lines. Going to remove the shifter and rod and the fuel line grommet up front to hopefully make the install easier. I dont anticipate it to be fun... Attached thumbnail(s) ![]() ![]() |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,554 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
Off topic: But what's with the oil coolers on the orange car... hmmmm (IMG:style_emoticons/default/idea.gif)
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,695 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
(IMG:style_emoticons/default/popcorn[1].gif) Were the OE plastic lines still good? Mine were. WD40 that front grommet and they will slip right thru w/o effort. Are you using Robert's or Chris' lines. Robert has a "how to" video for his lines. Probably the same for Chris'. 26 hr's huh? That's old age for ya. I take that long to decide if I want to, anymore. (IMG:style_emoticons/default/sad.gif)
Andyrew |
Plastic lines looked good. Fabric lines were ready to explode.
To many 914 fires for me to let a 914 go through my garage without new fuel lines... |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Slightly disappointed in thread title (IMG:style_emoticons/default/sad.gif)
I was hoping for "mini-V8" install, you know something in the 2 or 3liter department (IMG:style_emoticons/default/smile.gif) Too much work for me....but you are young and driven. Is the soon to be V8 car local? |
Andyrew |
San Jose local, yes. Member also has a 6 conversion.
I chose the thread title as my goal for this thread is 2-3 pages of how to and what all is required in a v8 build, showing how easy it can be. Also an easy reference to the owner to see progress and how it all goes together. |
matthepcat |
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California ![]() |
Slightly disappointed in thread title (IMG:style_emoticons/default/sad.gif) I was hoping for "mini-V8" install, you know something in the 2 or 3liter department (IMG:style_emoticons/default/smile.gif) Too much work for me....but you are young and driven. Is the soon to be V8 car local? I was thinking the same thing. Maybe the McLaren 3.8l twin turbo out of the MP4-12c |
screenguy914 |
Member ![]() ![]() Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California ![]() |
Not sure how fast you work or your personal level of thoroughness, but FWIW, I'd multiply your estimated time for completion by at least 3 to be more realistic. Sometimes even the most mundane procedures eats up time.
MHO, Sherwood |
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
he is one lucky guy (IMG:style_emoticons/default/shades.gif)
and will be one happy guy very soon (IMG:style_emoticons/default/driving.gif) but he will never be satisfied, ever (IMG:style_emoticons/default/smile.gif) |
Andyrew |
Slightly disappointed in thread title (IMG:style_emoticons/default/sad.gif) I was hoping for "mini-V8" install, you know something in the 2 or 3liter department (IMG:style_emoticons/default/smile.gif) Too much work for me....but you are young and driven. Is the soon to be V8 car local? I was thinking the same thing. Maybe the McLaren 3.8l twin turbo out of the MP4-12c An Audi 4.2 isnt out of the question for a future car (IMG:style_emoticons/default/smile.gif) In response to the oil cooler question http://www.914world.com/bbs2/index.php?s=&...t&p=2206628 Regarding time frame, I am pretty confident in my time. There is no fabrication involved, I have this figured out pretty well, I mean I uninstalled everything from the orange car(mine) in 4 hours, I have a detailed spreadsheet with hourly figures on what things will take me. And I have done this before multiple times... There is wiggle room figured in. (IMG:style_emoticons/default/sawzall-smiley.gif) |
whitetwinturbo |
Honey, does this wing make my ass look fat? ![]() ![]() ![]() Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California ![]() |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
You crazy! (IMG:style_emoticons/default/screwy.gif)
Andyrew |
Progress from tonight,
Fuel lines in ![]() Just kidding (IMG:style_emoticons/default/smile.gif) ![]() Still have about 45mins to install the rubber lines tank side and put in the tank, then I can cross that out. Right on schedule (IMG:style_emoticons/default/smile.gif) |
jimkelly |
on my V8 car i cut that hole below the fuel lines much bigger so i can access the fuel lines easier and get clamps on easier.
Attached image(s) ![]() |
Andyrew |
I will likely take the typical route of making the hoses ~ 2.5' long and coil it up under the tank, this way I can remove the tank and set it on top with the hoses connected.
Andyrew |
Firewall rust (IMG:style_emoticons/default/sad.gif)
![]() ![]() ![]() ![]() The owner and I are discussing the possibility of me doing the rust repair. |
Andyrew |
Andyrew |
Lo-Fi Version | Time is now: 3rd April 2025 - 06:42 PM |
