dimensions for antenna hole in fender?, need info on size of hole in fender |
buck toenges |
Oct 23 2015, 06:37 AM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
Anybody know the size of hole needed for antenna opening in drivers side front fender?
dflesburg |
Oct 23 2015, 08:01 AM
Senior Member Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
don't do that!!!!
for 20 bucks you can get an am/fm antenna that you can put under the inside trim and then on the inside of the windshield.. they work fine!!! |
boxsterfan |
Oct 23 2015, 01:28 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
don't do that!!!! for 20 bucks you can get an am/fm antenna that you can put under the inside trim and then on the inside of the windshield.. they work fine!!! (IMG:style_emoticons/default/agree.gif) |
Mueller |
Oct 23 2015, 01:36 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
I like those ideas above.....
if you insist, I would think there could be different sizes depending on the brand, I'd measure the antenna. |
DennisV |
Mar 3 2023, 08:00 AM
Senior Member Group: Members Posts: 579 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Anybody know the size of hole needed for antenna opening in drivers side front fender? I realize this thread is super old, but I don't see it was answered and I happen to have a photo handy. Perhaps it will help someone else down the road (bad joke intended). I'd call that 19mm? This is a 1970 914-6 that reportedly had: M453 Blaupunkt Frankfurt US retractable antenna with loudspeaker & noise suppression |
Lo-Fi Version | Time is now: 4th January 2025 - 10:16 PM |
