Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
I bought a speedo drive seal from GPR last week and it looks like the shifter seal only smaller. The haynes manual shows an 0-ring. Does anyone know which is correct before I try to replace it. The part number I have for the new one from GPR is 999.113.036.50.
Here is a crappy pic. Attached image(s) ![]() |
Allan |
phantom914 |
non-914-owner non-club member ![]() ![]() ![]() Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 ![]() ![]() |
There are two seals: an O-ring that seals the drive housing to the tranny case, which you can see when you remove the bolt and pull the drive out of the tranny, and a seal (which you already have) that seals the rotating shaft. You can see the seal when you unscrew the bottom half of the drive housing from the top half.
I can look up the number for the O-ring when I get home in a couple of hours. I know Pelican has the O-ring, but I don't see it on their site. It will come up if the Porsche part number is typed in though. Andrew |
phantom914 |
O.K. The O-ring part number is 999.701.084.50
Pelican should have them. That's where I got mine from. Andrew |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
I don't remember any seal but the o-ring on the speedo drive. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
KT Attached image(s) ![]() |
Allan |
Maybe it goes in here?
phantom914 |
Yes. The seal you showed goes there. Unthread the two halves and pull the shaft out.
Andrew |
swood |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None ![]() |
Mine seems to be a bit loose at that point. Could it be coming unthreaded or the seal going bad?? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Bruce Allert |
Hellions asleep ![]() ![]() ![]() ![]() Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest ![]() |
OK, so... if those 2 seals are replaced will it stop the leak?
Swood... did it work??? no more leak'n??? ........b |
Allan |
What I saw when I pulled it apart was that you can't replace the internal seal unless the machined casing can be split open.
Lo-Fi Version | Time is now: 26th June 2024 - 09:14 AM |
