Factoru 914-6 fuel pump with low pressure, Has anyone taken one apart and fixed them. |
toolguy |
Nov 21 2015, 08:49 PM
Senior Member Group: Members Posts: 1,275 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
I've got an original 6 with the factory fuel pump. . after sitting for 6 months, the pump runs but has low fuel pressure on the carb side. . Has great pressure on the tank return side. .no line obstructions. . . tested out of the car. . . won't lift fuel over level in the tank. . . anyone ever tried to adjust or repair one
Read down. . . Fixed !!! Attached thumbnail(s) |
914Sixer |
Nov 21 2015, 09:14 PM
914 Guru Group: Members Posts: 9,040 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Has fuel tank screen been replaced recently? May have picked up something.
toolguy |
Nov 21 2015, 10:37 PM
another issue I found, no screen in the tank, looks like someone ripped it out from the top so only bits left under the outlet nipple. . then there were no fuel filters anywhere. .
My next step was to pull the top of the pump off and see what the pressure adjustment looks like. . . just wondered if someone else had been successful in a similar task. |
McMark |
Nov 22 2015, 07:11 AM
I was able to find the o-rings in fuel-safe Viton, and have been able to get into the pumps to replace them. But there are two MAJOR issues with resealing a pump.
1. The outer housing is crimped onto the motor. These crimps are very difficult to pry apart and even harder to reinstall. If I were to even have a hope of making a reseal job work, I would expect to make special tooling to release and make those crimps. 2. The small silver 'button' on the side is the internal pressure relief. That cover is also crimped on, so there is a similar issue to #1, but also there is a seal inside that I haven't located (or tried). The best bet is to call Fuel Injection Corp (925-371-6551). They rebuild the 914-4 pumps, including machining a new pressure relief cap (button) from solid aluminum. They should be able to rebuild your pump. Keep us posted. I have two 914-6 pumps that need rebuilding. |
914Sixer |
Nov 22 2015, 07:41 AM
Collapsed/missing screen parts makes me wonder if they made it to the pump?
rgalla9146 |
Nov 22 2015, 08:53 AM
Advanced Member Group: Members Posts: 4,673 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I was able to find the o-rings in fuel-safe Viton, and have been able to get into the pumps to replace them. But there are two MAJOR issues with resealing a pump. 1. The outer housing is crimped onto the motor. These crimps are very difficult to pry apart and even harder to reinstall. If I were to even have a hope of making a reseal job work, I would expect to make special tooling to release and make those crimps. 2. The small silver 'button' on the side is the internal pressure relief. That cover is also crimped on, so there is a similar issue to #1, but also there is a seal inside that I haven't located (or tried). The best bet is to call Fuel Injection Corp (925-371-6551). They rebuild the 914-4 pumps, including machining a new pressure relief cap (button) from solid aluminum. They should be able to rebuild your pump. Keep us posted. I have two 914-6 pumps that need rebuilding. Got a couple myself. Anyone using one of the new Pierburg carb fuel pumps ? |
GeorgeRud |
Nov 22 2015, 09:08 AM
I've had great results with the Pierburg pumps. They easily fit up front by the steering rack, so you solve a possible vapor lock issue as well by getting it away from the engine's heat.
Mark Henry |
Nov 22 2015, 10:31 AM
Anyone using one of the new Pierburg carb fuel pumps ? The funny thing about that thread on the bird is no one really admits that they have tried the pierburg pump. George is the only peep here that states he has used them. Plus the only review on pelican is "I got it and ohhhh it is shiny and pretty ...can't wait to try it" And it is a 5 star review no less... QUOTE I have not installed this pump yet, but my pre-installation impression is that it is extremely well made, very small and light. I look forward to seeing it in action. WTF kind of totally fucking useless review is that (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/rolleyes.gif) |
porschetub |
Nov 23 2015, 02:49 AM
Advanced Member Group: Members Posts: 4,762 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Anyone using one of the new Pierburg carb fuel pumps ? The funny thing about that thread on the bird is no one really admits that they have tried the pierburg pump. George is the only peep here that states he has used them. Plus the only review on pelican is "I got it and ohhhh it is shiny and pretty ...can't wait to try it" And it is a 5 star review no less... QUOTE I have not installed this pump yet, but my pre-installation impression is that it is extremely well made, very small and light. I look forward to seeing it in action. WTF kind of totally fucking useless review is that (IMG:style_emoticons/default/WTF.gif) Yea I have reviewed and that rating drops back,there Chinese made regulator comes to mind,sent them an email regarding the fact it didn't fit properly,LOL they still list it,or I could send it back half way round the world @ my cost (IMG:style_emoticons/default/WTF.gif), Then I asked why they have a 914/6 conversion section when a large percentage of the parts are NLA ,they said they would review that.......nothing done. Having said all this they are best of a bad bunch really,still my main supplier and they seem to be generous with discount codes,they have most hard parts if not I go to Stoddards. Unless you are a really set on the correct pump I wouldn't bother reconing or buying a rebuilt unit, its well documented about failure of rebuilt units......maybe cause they are just old and were never made to be rebuilt,the Carter LP unit has a good rep. (IMG:style_emoticons/default/rolleyes.gif) |
Dave_Darling |
Nov 23 2015, 09:29 AM
914 Idiot Group: Members Posts: 15,067 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The Six conversion section was written a rather long time ago. I don't know when they would find the time to re-do it; I certainly don't have enough time for it. I believe that Tom was one of the main people to provide info for the section, and he is no longer with Pelican.
Anyway, on with the pump: I have been able to take apart the top section, clean the rotor and pucks, and re-assemble. The pump did not leak after I did that; I may have been lucky. I did not touch the crimped parts. The pucks are small, and easy to lose. Don't let them get away. The top has two layers, the housing layer and the cover. The housing is sandwiched between the cover and the main body of the pump. Both of them need to be in the correct orientation with the rest of the pump, or you get no pumping or the pump goes backwards! (Don't ask how I know that.) So mark the pieces before disassembling. --DD |
toolguy |
Nov 23 2015, 12:47 PM
So the answer is, YES, they can easily be taken apart and the pump portion serviced. .
In my case, the motor ran fine, i just did not have sufficient pressure to lift the fuel to the level of the carbs. . meaning it was putting out less then 1 psi. In my mind I was looking for some sort of blockage. . Last picture is of the pump head apart. . WARNING- As Dave D said, mark the pump, intermediate plate and head outlet before disassembling. . the intermediate goes back correctly in just one orientation, although you can put it back in 8 different variations.. The center hole that goes around the rollers is offset and must be in the proper place to coincide with the 3 outlet ports. . otherwise in could be out and suction could be pressure. . Beside the center lobe and 5 rollers, there is a small crimped cover with a small o-ring inside and over the plunger port. I reused the o-ring and re-crimped the cover tightly. . . Apparently the strength of the small spring regulates the outlet flow. . . the plunger is pushed toward the inward passage by the small spring. The plunger head then covers the inside port to the outlet tube. . the spring regulates the outlet flow. This plunger slides back and forth in the top cover, regulating gas flow either to the carbs, or back to the return port to the tank. In my case the plunger was gummed up with varnish and debris, and helf in a mostly closed position. . j. . It was really tight and had no movement but some PB Blaster and a few dental tools took care of that . Once it was all the way out, a little cleaning and it was easily sliding in the bore of the passage. First picture is the test arrangement i made, mostly to ensure no leaks and sufficient pressure. . On the initial test, the pump would not lift the fuel more that an inch above the pump level. . Now has plenty of pressure now, raised fuel 3 feet in elevation to the suspended can and I can stop it with my finger tightly held over the outlet port. . I plan on running an outlet pressure regulator and gauge to insure no pressure in excess of 4 pounds. . So for posterity, they can be taken apart, cleaned and reassembled. . just be careful about exactly how it comes apart. I am still puzzled as to what actually controls the outlet pressure as the bypass plunger seems to be more related to flow rather than pressure. Maybe the strength of the little spring , but at this point , it works and that's good enough for now. . pressure could be a relationship of the motor speed and the roller dimensions. . Attached thumbnail(s) Attached image(s) |
pete000 |
Nov 23 2015, 02:48 PM
Senior Member Group: Members Posts: 1,886 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I had an old 914-4 pump laying around and took it apart. It was locked up from gum and varnish. I cleaned it up and it runs and pumps. Seems not to leak either.
I did not take the crimp cap off though. Nice write up ! Show more pictures of the new found Six ! |
pete000 |
Nov 23 2015, 02:51 PM
As for no filter this reminds me. The Porsche 914-6 PET catalog shows no refrence for a fuel filter which seems odd. I have seen the filter location on several cars in various places. I was wondering where it was located from the factory?
I think it should be in front of the fuel pump and thats the way I run mine. I have also seen them in the engine compartment which would be behind the fuel pump. Just curious where the factory put them? |
rgalla9146 |
Nov 23 2015, 04:52 PM
Factory ?
Not original on a 6, AFAIK only the screen in the tank. Anyone know otherwise ? Attached is pic of my added filter. Oh, another thing. Before disassembling a 3 port Bosch pump scribe a line across the edge of the three sandwich pieces to aide orientation on reassembly. Where can the Viton O rings be sourced ? Attached thumbnail(s) |
toolguy |
Nov 23 2015, 06:49 PM
the o-ring in the crimp cap appeared to the a square ring, not round. .
Viton rings available on McMaster / Carr. . If you don't take the crimp cap off, you can't remove the plunger and spring assembly . . Needs to come off if plunger or piston is sticking. . |
Lo-Fi Version | Time is now: 6th January 2025 - 01:01 AM |
