chassis number decoder, is this right? |
914 RZ-1 |
Feb 21 2016, 05:09 PM
Porsche Padawan Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I'm looking for something that will tell me what the numbers mean on the chassis number. I find the "chassis number decoder" info shown. However, it doesn't seem to work. Am I missing something? My chassis number-found on the inside front fender on a plate (is this supposed to be the same as the VIN number?)-is 472 2910951, door sticker says car was built in Feb '72.
So using the decoder it seems my car was built in the 29th week of the year (29) on Monday (1) at the Karmann factory (9) and it was the 51st car built that day. By the way, the chassis plate states the car was "Made in Germany", but there was a West and East Germany back then, so what gives? Attached image(s) |
Coondog |
Feb 21 2016, 05:20 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Your correct with the chassis number date that your car was assembled. Key word assembled. As far as East and West, after 1960 I seriously doubt any Porsche was assembled in East Germany.
Larmo63 |
Feb 21 2016, 06:17 PM
Advanced Member Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
The VIN and the chassis numbers are different. The VIN is located on the driver's side windshield A pillar plate, on the sticker inside the driver's side door below the striker, (which also states the month/year of build,) also, on top of the right fender under the hood, and on an aluminum plate on the side of the inner front right fender, inside the front trunk.
The black and aluminum plate inside the driver's door to the front, is the chassis number and that same number will also be on the rear trunk floor on most cars. Different cars/years are stamped in different areas of the rear trunk. My chassis plate says: "Made in Western Germany." The lower part of this plate also has stamped in it the original color code of the chassis. |
dlkawashima |
Feb 21 2016, 09:57 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
SirAndy |
Feb 22 2016, 12:12 PM
Resident German Group: Admin Posts: 41,972 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Am I missing something? My chassis number-found on the inside front fender on a plate (is this supposed to be the same as the VIN number?)-is 472 2910951 That's your VIN... As stated above, the chassis number is on the small black plate that can be found on the drivers side front door pillar. (IMG:style_emoticons/default/shades.gif) |
914 RZ-1 |
Feb 25 2016, 06:28 PM
According to the Haynes manual the chassis number "...is in the front luggage compartment on the top of the right wheel well." This number matches the VIN (from sticker on pillar behind driver) on my car. Hence my question.
My car does not have a VIN plate on the window pillar. I think it was made in Canada. The plate on the front door pillar is painted over. Thanks for the reference picture. I might try to use some paint stripper to get the paint off so I can see the number. Anybody ever had to do this? Does the stripper take off the ink on the plate? |
boxsterfan |
Feb 25 2016, 09:24 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
According to the Haynes manual the chassis number "...is in the front luggage compartment on the top of the right wheel well." This number matches the VIN (from sticker on pillar behind driver) on my car. Hence my question. My car does not have a VIN plate on the window pillar. I think it was made in Canada. The plate on the front door pillar is painted over. Thanks for the reference picture. I might try to use some paint stripper to get the paint off so I can see the number. Anybody ever had to do this? Does the stripper take off the ink on the plate? http://www.914world.com/bbs2/uploads/post-179-1217454646.jpg If the Karmann plate in the driver's door area is painted over and you can't make out the numbers, look in your rear trunk for chassis number (which is not the VIN#). There's one other spot to look after that but I'm not going to say. Decode from there. |
SirAndy |
Feb 25 2016, 09:33 PM
According to the Haynes manual the chassis number "...is in the front luggage compartment on the top of the right wheel well." In that case, the Haynes is wrong. The number stamped on the top of the wheel well is the VIN, not the chassis number. (IMG:style_emoticons/default/shades.gif) |
JeffBowlsby |
Feb 25 2016, 09:46 PM
914 Wiring Harnesses Group: Members Posts: 8,806 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Haynes is a British publication. To them, they may think 'chassis' is the same the VIN. But they are clearly different.
914 RZ-1 |
Mar 29 2016, 05:54 PM
I finally got around to taking all the paint off and found the chassis code: 0729595.
Based on this, my car appears to be the 95th one made that day (Tuesday, Feb 8, 1972 to be exact). Is that right? That seems like an awful lot of cars for one day. If they were working 8 hour shifts, that's almost 12 cars an hour if mine was the last one! I used Crown Tuff-Strip. I spayed it on an old toothbrush then rubbed it on the label. It did not take off the black on the label, just the paint. |
stevend914 |
Dec 11 2018, 03:08 PM
Member Group: Members Posts: 378 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
Question on counting the weeks: In my case the first of January is on a Thursday so the first week of the year is a partial week, is that week still considered the first week or is the first full week of the year considered the first week? (IMG:style_emoticons/default/unsure.gif)
Thanks |
jagalyn |
Dec 12 2018, 08:18 PM
True Patina Group: Members Posts: 414 Joined: 31-January 06 From: Scandia, MN Member No.: 5,503 Region Association: None |
My car was the 110th car built on Monday, April 9th, 1973.
aharder |
Dec 12 2018, 09:04 PM
Advanced Member Group: Members Posts: 4,606 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
Mine was the 6th one on Monday October 1974 (IMG:style_emoticons/default/biggrin.gif)
Larmo63 |
Jul 7 2019, 10:37 PM
How many 914s did the Karmann factory pump out per day?
By my chassis #, my car was the 578th car of the day on August 28th, 1972. I don't think they built that many per day but I could be wrong. |
Craigers17 |
Jul 8 2019, 04:03 AM
Senior Member Group: Members Posts: 814 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
Looks like the made 21,580 914's in 1972, not including 240 sixes. So if you base that on a 5 day work week, roughly 261 work days, they would have pumped out roughly 82.68 cars/day if my math is correct.
But who knows? Did they work 5 days a week, 6?, 7? Did they manufacture cars in all 12 months? Were the same # of cars produced on a Monday as a Friday? If Bob can install "x" amount of tail light housings in 8 hours, and Bill can install "y" amount of door handles in 5 hours, how many front bumper caps can Mary install in 4 hours, provided Raul can install 21 antennas in 7 hours? (IMG:style_emoticons/default/confused24.gif) |
jagalyn |
Jul 8 2019, 05:46 AM
So, what does the ‘5’ stand for? |
Larmo63 |
Jul 8 2019, 09:14 AM
If the "5" isn't included in the car number for that day, then my car would be the 78th of the day which makes more sense.
I know this doesn't matter a hill of beans, I'm just wondering. |
914 RZ-1 |
Jul 13 2019, 06:06 PM
I was looking at this post again. Thought I'd add some more info.
The week of mfr is counted from 1 even if it's a partial week. 1972 started on a Saturday, so that's week #1, even though it's one day. So 0729595 would mean: 07: week of Feb 7, 1972 2: Tuesday (Feb 8, 1972) 9: Karmann factory in Osnabrueck 5: what does this mean? Anyone know? I couldn't find anything. 95: 95th car made that day. |
SirAndy |
Jul 13 2019, 08:54 PM
Not sure why it starts with a 5 in that column but if there were more than 99 cars that day it will roll over to a 6 ...
For example 0129606 would be the 106th car built that day. (IMG:style_emoticons/default/smile.gif) |
EdwardBlume |
Nov 22 2020, 12:39 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
Found this tag on the ABM
Chassis born on July 4th 1974 Attached image(s) |
Lo-Fi Version | Time is now: 15th January 2025 - 07:54 AM |
