Rhodes71/914 |
Glacier ![]() ![]() ![]() Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 ![]() |
Trying to adjust the ride height and I can't figure out what part is the cap that I need to remove in order to pry the adjuster pivot off.
I need to re-index the torsion bar. Attached image(s) ![]() |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
the entire part that has the threads is the "cap", it'll come straight out.....you might have to pry it since rust/corrosion has set in.....
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
does this help ?
Mueller |
cap:
Rhodes71/914 |
Thanks guys, I thought that was the part but in reading some old threads I thought that "cap" and "lever" were two different things.
Just didn't want to start prying and break something, not that I've done that before (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
Mueller |
the "cap" some people mention is on the front of the a-arm assembly. Sometimes when one needs to remove the torsion bar, it's easier to force it towards the front of the vehicle...when you do this, the "cap" gets knocked out.
it's basicly a steel disc that can be put back in..... |
Joseph Mills |
on a Sonoma diet now... ![]() ![]() ![]() Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 ![]() |
Since we're talking about torsion bars...
Do they have a number stamped on the end indicating their mm size like the swaybars do? If not, can you determine their size without removing them? Maybe partway? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
briefly discussing indexing the bar. as per haynes, they recommend moving the a-arm down in the arc as far as it will go before putting on the adjusting lever. too much? is there a general rule of thumb about gaping the stop face of the lever, right of the bat?
k |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,196 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
they do but often that stamp may be on the inside. The other end will have a L or R stamp. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 01:44 PM |
