MecGen |
8 Easy Steps ![]() ![]() ![]() Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 ![]() |
Hey
This is what I did today, I made a 12volt power distribution center, in the pass side foam (spare). In the pic everything mounts to a stainless steel plate/sheet , I plan to finish the box in the same way and add a hinged cover (spare parts from a scrapped coffee truck). The relay board is from a Suzuki, has 3 fused 12volt, 30amp relay controling 1 fused 12 volt switched and 1 30 amp 12volt switched output (which I split to 3) Just to be clear : 12 volt batt constant = 12volt 12volt when key is in run position only = 12volt switched. Everything is nicely protected by a maxi 40 amp, which I mite downsize when I figure out what its for.... (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) Big radio, sub alarms Engine swaps, ecm controle, fan harness junction, HEATER Or just use the box to hide your personals.... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Fun project easy to do. Hope it gives ideas. Regards Joe Attached image(s) ![]() |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Is that in the foam piece where passenger feet rest ? Looks really nice !
Lo-Fi Version | Time is now: 25th June 2024 - 06:06 PM |
