ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,224 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
It begins:
![]() Just arrived from Hawaii... ![]() ![]() ![]() 3.6L 964 motor. Destined to become a 4.0L with 993 RS cams. I am keeping the FI so it is a bit more drivable than the MFI motor I have now. I actually started this years ago. I bought a 3.6, but it turned out to be unusable. But I had already bought the LN engineering pistons, cylinders, rods and stud kit to make it a 4.0. So now I get to use all that stuff!. |
whitetwinturbo |
Honey, does this wing make my ass look fat? ![]() ![]() ![]() Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California ![]() |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Build off challenge?
That being said Im looking forward to this engine build (IMG:style_emoticons/default/smile.gif) |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
4.0 Porsche motor in a 914...... (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
0396 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California ![]() |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
stevegm |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States ![]() ![]() |
Interesting engine build. Are you planning to do the 2017 Build-Off Challenge?
theleschyouknow |
Senior Member ![]() ![]() ![]() Group: Members Posts: 524 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None ![]() |
sweet glad you found one! let me know if you ever need a hand I'm not much of a wrench but I can follow directions (IMG:style_emoticons/default/beerchug.gif) cjl |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Dang...that will be a fun motor!
I figured only pineapples got exported from HI (IMG:style_emoticons/default/smile.gif) |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,781 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
It begins: ![]() Just arrived from Hawaii... ![]() ![]() ![]() 3.6L 964 motor. Destined to become a 4.0L with 993 RS cams. I am keeping the FI so it is a bit more drivable than the MFI motor I have now. I actually started this years ago. I bought a 3.6, but it turned out to be unusable. But I had already bought the LN engineering pistons, cylinders, rods and stud kit to make it a 4.0. So now I get to use all that stuff!. Great find,had the original car suffered from an interior or engine fire?. What plans do you have for a gearbox,stock or 915 ?,cheers. |
ClayPerrine |
naro914 |
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States ![]() |
0396 |
If you're going to install factory 993RS cams. .you better buy now às I believe there's only one more in stock at the factory.
ClayPerrine |
I plan on using a Boxster 6 speed for a transmission. How?? Bubble gum and bailing wire. (IMG:style_emoticons/default/biggrin.gif) Seriously, I have been researching this for a while now. I will document it here for everyone to see. If you're going to install factory 993RS cams. .you better buy now às I believe there's only one more in stock at the factory. I am not using "Real" 993RS cams. I want to leave them for someone who really needs them for a 993RS. I will be getting aftermarket cams with the same grind. |
ClayPerrine |
ClayPerrine |
A little gratuitous engine porn:
(IMG:http://www.914world.com/bbs2/uploads/post-1143-1229836904.jpg) I started this project years ago, and it got sidetracked by life (layoff from my job) and a bad crankshaft. Original 4.0 Build Thread I am glad it is finally going again. |
Mueller |
I plan on using a Boxster 6 speed for a transmission. How?? Bubble gum and bailing wire. (IMG:style_emoticons/default/biggrin.gif) Seriously, I have been researching this for a while now. I will document it here for everyone to see. I'm not giving up on my quest for using a Boxster transmission yet , hopefully you'll figure it out before I get back to mine so it'll be easier for me (IMG:style_emoticons/default/smile.gif) |
ClayPerrine |
Interesting engine build. Are you planning to do the 2017 Build-Off Challenge? There is an official contest? I thought it was just for motivation and sharing with the board. I just read the thread. I don't qualify. I am only doing a drivetrain replacement. |
kid914 |
ALWAYS lead...NEVER follow!!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,535 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada ![]() |
4.0 ? (IMG:style_emoticons/default/w00t.gif)
I thought of doing this awhile back. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:16 AM |
