Beebo Kanelle |
Member ![]() ![]() Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region ![]() ![]() |
My switch for the headlights / instrumentation is shot.
What is the best way to replace it? Thanks in advance. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,326 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I pulled mine from the dash and replaced wire by wire. There's also a color diagram on pelican if you get messed up. I did the same wire by wire switch to replace my fuse panel.
Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
Unscrew the knob. Remove the silver retaining nut (slotted) with a coin or other item that will fit the slots and it should drop right out!
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,332 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
There are two closely related switches: one has ten spades, the other eleven
Beebo Kanelle |
thanks to all!
Lo-Fi Version | Time is now: 20th June 2024 - 06:20 AM |
