Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,199 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
injunmort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States ![]() |
there should be 2 studs at the back of the trans, one gets ground cable from post on trunk floor, both get the muffler hanger bracket. the other picture, if i am looking at correctly is from battery to pos side of starter.
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
The wire from the alternator that I think attaches to the starter? Does that go on same post as the battery cable? Yes, same post as battery QUOTE There is a screw post at end of tranny. What attaches to that? That's one of two studs for the muffler hanger. The ground strap goes under one of the top nuts that holds the gearbox together |
r_towle |
I can't recognize any of that.....where is all oil, grease and dirt?
Lo-Fi Version | Time is now: 26th June 2024 - 01:32 PM |
