orbit398 |
Member ![]() ![]() Group: Members Posts: 139 Joined: 29-April 15 From: League city, Texas Member No.: 18,681 Region Association: Southwest Region ![]() |
Not sure what to check an looking for pointers.
Ran fine this morning in garage, every thing worked. I had the fuse panel unmounted as I finished installing the DPD under dash blower and tied into a wire position that comes on once the key is on. Put it all back together and now it doesn't crank. Weird. Battery has a charge. Just wondering what the culprit might be. |
falcor75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia ![]() ![]() |
I had that issue recently, was the small wire that had come loose from the starter.
orbit398 |
Update
I have a loose connection somewhere. Messed around with the fuse panel relays and then, the little click noise I hear when I turn the key on was heard again. Engine started right up. What is that thing that clicks when the key is turned on as it seems to work and not work as it wants. So I figure I'll change that out and clean more connections thanks |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
Click or continues sound for a seconds? it can be the fuel
pump. |
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,193 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Not sure what to check an looking for pointers. Ran fine this morning in garage, every thing worked. I had the fuse panel unmounted as I finished installing the DPD under dash blower and tied into a wire position that comes on once the key is on. Put it all back together and now it doesn't crank. Weird. Battery has a charge. Just wondering what the culprit might be. Did the engine warm up? It would seem that Otto, or whomever at Bosch, signed off on the solenoid design sheet without testing them hot. In some cases the solenoid will draw juice but freeze and not move. You don't even get a click. Ask me how I know 1,000 miles from home. |
worn |
Update I have a loose connection somewhere. Messed around with the fuse panel relays and then, the little click noise I hear when I turn the key on was heard again. Engine started right up. What is that thing that clicks when the key is turned on as it seems to work and not work as it wants. So I figure I'll change that out and clean more connections thanks Probably the fuel pump. If you push on the gas pedal you will also hear fuel injectors - if it is quiet around you. |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Not sure what to check an looking for pointers. Ran fine this morning in garage, every thing worked. I had the fuse panel unmounted as I finished installing the DPD under dash blower and tied into a wire position that comes on once the key is on. Put it all back together and now it doesn't crank. Weird. Battery has a charge. Just wondering what the culprit might be. Chances are something you touched is making an intermittent connection. Check all the wires you touched. Keep in mind that spade connectors on the fuse panel actually touch a very tiny bit of the spade and oxidation can wreak havoc on dependable operation. Clean any spades you touched. Also clean the fuse connections. They can oxidize very easily and if bumped, can cause intermittent contact. |
orbit398 |
It's not the fuel pump. I have a kill switch for that and it's way in the back by the motor. I know when it runs or doesn't. I also have carbs on my 2.0 liter.
I'll just rework all the spade connectors to the fuse panel as well as mess with the relays. I am sure it just a crappy connection somewhere..... Least is started back up and ran fine. So, its just one more thing to deal with.... |
Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,474 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
Spend a $100 and get a new fuse panel from J West. You'll be glad you did. I got tired of messing with those old torpedo fuses.
Lo-Fi Version | Time is now: 26th June 2024 - 08:15 AM |
