Schnell944 |
Member ![]() ![]() Group: Members Posts: 121 Joined: 4-January 03 Member No.: 86 ![]() |
got a new relay and looked at the Haynes manual and couldnt find where this thing goes....doesnt look like its shaped for the relay spots in the fuse box, plus those are for other things. also....i how do u get to the hazard light switch behind the pull knob. haynes says just to take it out, but it doest fit through the little hole. thanks!
Schnell944 |
no one really knows?
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
Unscrew the knob, and it should come out the back. Cant help with the flasher relay. Did you unscrew the fuse block, there are a few relays on top of it..
Lawrence |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None ![]() ![]() |
IIRC, the relay is under the dash.
I would go look, but it's raining like hell. |
MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
Take the 2 screws out of the fuse panel, it drops down & the relay is above it. Mine is just laying up on top of the fuse panel.
Schnell944 |
ya, i'd go look now too, but its dark AND raining
iansale |
Newbie ![]() Group: Members Posts: 21 Joined: 12-June 03 From: Havertown, PA Member No.: 810 ![]() |
It might be the square relay in this picture. The reason I'm not certain is that, on my car, there is a second larger "square" relay that is just sort of resting on the lower dash shelf. I think that the one hanging loose is for the wiper intervals.
MarkV |
There it is.
Attached image(s) ![]() |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(iansale @ Jun 19 2003, 07:58 PM) I think that the one hanging loose is for the wiper intervals. nope, wiper interval is in the front trunk ... flasher relay is behind the dash, above the fuse panel. there's actually a little hole in the bottom of the dash where the relay is supposed to be mounted, but most of them just just dangle there ... Andy |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
There are two square relays. One is the high/low beam relay, the other is the flasher.
The hazard switch is removed in the same way as the other dash-mounted switches--unscrew the knob, then find a way to unscrew the round metal plate that acts as a nut to hold the switch to the dash face. I have been able to use a small flat-head screwdriver to push the "escutcheon" (as the manual calls it) to loosen it. When it's loose, you can use finger pressure to turn it. Unplug your battery (-) terminal first, though. The switch will fall down inside the dash and one of the "hot" wires might short out on something... --DD |
SirAndy |
QUOTE(Dave_Darling @ Jun 20 2003, 04:08 PM) I have been able to use a small flat-head screwdriver to push the "escutcheon" (as the manual calls it) to loosen it. When it's loose, you can use finger pressure to turn it. i have been using a "Quarter" (IMG:style_emoticons/default/cool.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 06:29 PM |
